Make a FreeCAD high school version
Re: Make a FreeCAD high school version
Crossposted with Herbert, who is, of course, right.
I will strip down some toolbars and see what that looks like. I'm not sure I can get what I want without hiding the properties tab, I really don't want anyone in there. Many will see this as a video game and try every option and value so things can get messed up quickly. Don't get me wrong here, I have lots of faith in kids but there are limits that need to be in place for a good teaching tool. The goal to success is the "Kiss approach".just personalize the Toolbar and you have all what you need for a easy use
I could imagine FreeCAD would start up with only one workbench . I could use the "Complete WB" to start but I still have an issue with properties. Edit: I see using Part Design and Sketcher.
I have noticed that I can drag the properties window down and make it disappear, does anyone know how I can make that permanent? Maybe modify the config file.
Thanks
Thanks
Menue -> Panels, disable Combo View, enable Tree View. It will stay like you set it.
Gruß Herbert
What I see here; In Part Design, when I leave sketch FreeCAD auto opens combo view, then the properties are available once again.
Thanks
Thanks
Hi freedman
It's because you need the Propertie Box...
Gruß Herbert
- microelly2
Years ago I started such a school workbench.
But after a year I returned to the core FreeCAD.
At school we can teach the workflow and the pupils learn the tools needed.
Starting with a school interface requires a relearning when the tasks become complexer in the 2nd year.
I only use special menus/workbenches for special projects
I want to use a standard version of FreeCAD configured with unpopulated screen items to different levels, the simplest version (CAD-100) is stripped down to the basics. I would then repopulate some in CAD-102, 103 ect. Many things can be drawn in Part Design without the properties panel so I thought it would be good to remove it for CAD-100. Maybe I can't hide somethings without compiling myself.
The big hurdle is getting educators to test something. If they get lost when testing then it surely won't make it to the class room.
On Windows, if it's using existing FreeCAD cmake options I'm willing to compile and package custom versions. I'm not sure this is the right path, but I have enough interest to invest some time in experimenting with different solutions.
"fight the good fight"
sgrogan, thank you. I will make some observations on a starting place over the next few days. I have some experience with customizing toolbars so I should be able to post some pictures of a few basic screens.
Thanks again.
Thanks again.
