3D scanner data to FreeCAD file
jwackito
Post by jwackito »
Hi guys. I'm working on a 3D scanner as a science project based on this one
http://hackaday.com/2013/02/14/3d-scann ... -in-a-day/
The idea is to write the dots position directly into a FreeCAD file. There is a python library that allow me to do this? I mean, a native python library that allow me to create a FreeCAD document, add the dots position and save the document without using freecadcmd feature?
Thanks in advance.
Regards from Argentina.
shoogen
Re: 3D scanner data to FreeCAD file
Post by shoogen »
Instead of running freecadcmd you should be able to run use FreeCAD as a normal python module. But is not a 'seperate' library, you would FreeCAD by itsself.
FreeCAD can also import Point clouds from a simple text file. When dealing with data from a MS kinnect, the fact that points can't have an individual color might be considered a drawback.
jwackito
Post by jwackito »
Thanks shoogen. Maybe the point cloud text file is a better approach. Have you a reference about the file format?
shoogen
Post by shoogen »
one point per line. axes separated by whitespace. Filename extension '.asc'
# Points001 Number of points: 3
0 0 0
1 2 0
-2 1 0
if you are familiar with regular expression, you might want to have a look at the import routine.
https://github.com/FreeCAD/FreeCAD_sf_m ... os.cpp#L62 PointsAlgos::LoadAscii(PointKernel &points, const char *FileName)
jwackito
Post by jwackito »
Thanks again shoogen. The format seems sweet and simple, just the way I like it... Definitely, RegExps are not one of my strong points but the code seems to accept points with exponential notation! Nice... I will keep you informed about my process if you are interested.
Best regards and thanks again.
valioni
Post by valioni »
it also works exporting the point cloud from meshlab with the extension .xyz - without the normals (really important) and changing the extension to .asc (used save as in notepad)
-but freecad inserts the point cloud in mm no matter what units you use (tried metric) - big problem with scaling because it doesn't work with point clouds - so you have to draw the profile you're interested in and scale that
using freecad 0.16.5018 on win7 64, meshlab 1.3.3
GumbleTea
Post by GumbleTea »
Hello, I decided not to start a new topic about my problem. I'm trying to use freeCAD with scanned model. I scan using Kinect and tryed Scanect and Demo Artec Studio software. I managed to get quite fine result in both, but when i'm trying to import it to freeCAD it's absolute mess. What am I doing wrong?
GumbleTea wrote:What am I doing wrong?
A big mistake was that you didn't make clear what you have done, nor what exactly the problem is. "An absolute mess" shows the direction but the world of mess is very wide. I guess you expeced more advice than "Clean up the mess!" so you should at least tell us:
- What was the input to FreeCAD
- What was the result
- What did you expect
An image could be helpful.
jmaustpc
Post by jmaustpc »
FreeCAD version data could be also relavent.
GumbleTea
Post by GumbleTea »
Sorry for dissapearing for a long time. For that issue, I've asced Artec support and they explained me how to clean the mesh before exporting. Now it works fine.
