Please demonstrate using a remote text editor to substitute the Python editor in FreeCAD
Re: Please demonstrate using a remote text editor to substitute the Python editor in FreeCAD
Postby Kunda1 » Mon Oct 05, 2020 7:10 am
Cyril wrote:
Sun Oct 04, 2020 3:33 pm
I have updated my article with enhanced auto-completion using freecad-stubs.
Awesome!
hsbank
Postby hsbank » Wed Oct 07, 2020 6:53 am
Based on Cyril's explanation, I wanted to add Windows version. I have seen a few different questions from Windows perspective. I will try to keep as generic as possible in terms of folder representation. As Cyril explained in the video, create .env file and include the followings in .env file.
FREECAD_LIB=../FreeCAD_0.19.22522/lib
FREECAD_MOD=../FreeCAD_0.19.22522/Mod
FREECAD_STUBS=../FreeCAD_0.19.22522/freecad-stubs/out
PYTHONPATH=${FREECAD_STUBS};${FREECAD_Mod};${FREECAD_LIB};${PYTHONPATH}
That said the project parent folder is the same location as the FreeCAD_0.19.22522 AppImage (Conda binary). Therefore, I have ../ structure in .env. Alternatively, you can write the lines below. Here, <WHEREVER YOU HAVE YOUR FREECAD> is the installation location.
FREECAD_LIB=C:\\<WHEREVER YOU HAVE YOUR FREECAD>\\FreeCAD_0.19.22522\\lib
FREECAD_MOD=C:\\<WHEREVER YOU HAVE YOUR FREECAD>\\FreeCAD_0.19.22522\\Mod
FREECAD_STUBS=C:\\<WHEREVER YOU HAVE YOUR FREECAD>\\FreeCAD_0.19.22522\\freecad-stubs/out
I included stubs after downloading zip file from GitHub and opening the archive in FreeCAD installation folder as /freecad-stubs. In Windows 10, while writing PYTHONPATH you need to use ; instead of : . After adding .env file you need to restart VS Code.
I also use .vscode/settings.json for my project folder.
    "terminal.integrated.env.windows": {
        "PYTHONPATH": "${env:PYTHONPATH};${workspaceFolder}/src",
    "python.envFile": "${workspaceFolder}/.env"
In settings.json, you see that I have /src folder in which I keep my python scripts and modules that I developed. Having settings.json is not a must unless you would like to keep your developed python code -or module- in a separate folder.
Thank you Cyril for the video.
drmacro
Postby drmacro » Wed Oct 07, 2020 10:43 am
I started modifying the grbl post yesterday in VS Code. I like linting and the modified file gets read each time I run it in Path.
But, i definitely need to find the forum post about setting up for debugging. Would be nice to be able to checkout variables at runtime. :roll:
My beginners, written treatise: Learning FreeCAD
Cyril
Postby Cyril » Wed Oct 07, 2020 4:42 pm
You are in the right thread :lol: (see previous posts)
I am still using ptvsd but yesterday I saw that vscode has a new debugger called debugpy. I am currently looking at it to debug Blender addons.
I blog about HVAC / BIM / Energy : pythoncvc.net. If you like you can follow the RSS feed.
drmacro
Postby drmacro » Wed Oct 07, 2020 6:57 pm
I've added the python and json code as specified in the FC wiki: https://wiki.freecadweb.org/Debugging
But, am still confused about a couple things.
- what is the sequence to make the connection between FC and VSCode debugger.
- VSCode basically won't do anything because it knows not where "import FreeCAD" module resides, thus can't import.
