Fasteners WB, shape is not a shell
Hy everybody
I use Freecad:
OS: Windows 7
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
If i create a nut M6and set thread to true it looks great.
BUT if i create a nut smaller than M6 i get a error: Shape is not a Shell
does anybody knows the problem?
I reinstalled the WB and my freecad more than 3
I use Freecad:
OS: Windows 7
Qt version: 5.6.2
Re: Fasteners WB, shape is not a shell
Works here. Try opening and recomputing the attached file.
OS: macOS High Sierra (10.13)
Version: 0.19.18775 (Git)
Hash: 9e93e621f9d5332114d29ea316f27aa6698eb70b
Python version: 3.7.3
Qt version: 5.12.5
Locale: English/Germany (en_DE)
Qt version: 5.12.5
- M5x12.FCStd
- (55.68 KiB) Downloaded 35 times
Your file works. But if a create another nut, it crash....
test this, please
test this, please
Sorry didn't read your post properly enough.
I can confirm the issue for threaded nuts for M5 and below.
Is there any solution?
You can try using screwmaker macro. But may I ask what for you really need this? Threads are usually not modeled explicitely, especially nuts are readily available. Most 3D-printers won't print very small threads anyway reliable enough, so you have to rework them anyway.
If it is for a show case you may try one of the methods described in the Thread for Screw Tutorial, which also tells you how to do a thread all by yourself.
This issue started appearing with the OCC version 7.3.
Thank for your answers
Can I downgrade occ or set down?
Hi Shai
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.18738 (Git) AppImage
Hash: f65a72deb71e8b2a18c849adc9a900c3d113d51b
Qt version: 5.12.5
Edit: It only works if i not use PD! If i use PD i can create M5 Nut as smallest size.
i don't have it at
Qt version: 5.12.5
Gruß Herbert
I have a 1mm thick plate and need a m3 nut in this. Do you think, it will work, when i create a 2.5mm hole and try to cut the thread with the screw?chrisb wrote: ↑Wed Nov 27, 2019 7:03 am You can try using screwmaker macro. But may I ask what for you really need this? Threads are usually not modeled explicitely, especially nuts are readily available. Most 3D-printers won't print very small threads anyway reliable enough, so you have to rework them anyway.
