How to use all your ram and crash freecad
Mongrel_Shark
Postby Mongrel_Shark » Thu Nov 28, 2019 10:35 pm
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
This is not a help request or bug report. Just something I found amusing I'd like to share. I knew what I was doing was probably a bad idea. Did it anyway :mrgreen: I would however be open to suggestions on achieving a similar end result with less resource consumption.
So I have a job designing a blind enclosure, like a Pelmet. The blind is the roll up kind. I wanted to model the rolled up blind so I could send client some pretty screenshots.
Turns out making it full size, 1600mm wide with 20 turns was a very bad idea. Gobbled up 64gb of ram (all I have) then started gobbling up swap space on the HDD (page file for windows users) gobbled up 64gb of swap (all I have), then promptly crashed. all in about 2 min. I've not seen anything use all my ram and swap before, Freecad is usually pretty tame too. I think my previous record was about 20-30gb with multiple large assembly files open.. Usually over 50gb for one program is a Blender of Firefox thing. Still chuckling :mrgreen:
I have a version of the file attached. I haven't actually done the sweep operation in this version. Because the file is 1.2mb and over the forum limit. Also I wouldn't want someone with 8gb ram to try and open it :lol: So attached file is safe to open on any system. Proceed with sweep operation at own risk :mrgreen:
Anyway if you want to see how much ram you can use. I'd suggest modifying constraint 11 in sketch001 before starting a sweep on the spiral shape binder. A small number like 5-10mm is probably sensible to start with.
Anyway I made the cloth roll smaller, only 100mm wide, and it only used 30ish gb of ram :mrgreen:
Now I have made it 150mm and am writing this post while I wait for recompute to finish. Here is a screenshot from htop :mrgreen:
This has been replicated in FC0.18.4 and 0.19 :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Final thoughts.... I wonder what happens if I try to fillet a skinny face on the blind roll? :mrgreen:
blind assembly rough 0.1.FCStd
(130.83 KiB) Downloaded 1 time
Mongrel_Shark
Re: How to use all your ram and crash freecad
Postby Mongrel_Shark » Thu Nov 28, 2019 11:07 pm
P.S. I figured out a better way.
I simply used the PART workbench Extrude feature to extend the spiral in a third dimension. Hardly used any resources. Looks fine for what i wanted.
Better blind roll.FCStd
(159.97 KiB) Downloaded 3 times
