After this commit: https://github.com/FreeCAD/FreeCAD-Home ... 3f6699ecc2 the whole freecadweb.org seems quite broken
Anyone else experiencing this?
EDIT: See here also: https://forum.freecadweb.org/viewtopic. ... 06#p352632
Thanks. Would it be better if in the future I just make a pull request? I was trying to save you work not make new workkkremitzki wrote: ↑Sun Dec 08, 2019 7:00 pmIt was actually my fault as I left the bad Travis config which caused it originally in the repo after fixing it the last time so it was just a matter of whoever committed to the repo next. I fixed that and so now everything should hopefully be back to normal.
Unfortunately so, until we get an automated way to deploy, since changes will still have to be uploaded manually.sgrogan wrote: ↑Sun Dec 08, 2019 7:03 pmThanks. Would it be better if in the future I just make a pull request? I was trying to save you work not make new workkkremitzki wrote: ↑Sun Dec 08, 2019 7:00 pmIt was actually my fault as I left the bad Travis config which caused it originally in the repo after fixing it the last time so it was just a matter of whoever committed to the repo next. I fixed that and so now everything should hopefully be back to normal.![]()
