add to part design the "surface design"
Piero69
Postby Piero69 » Fri Dec 13, 2019 3:04 pm
i feel useful to add to part design (solid modeling) the surface modeling that in certain cases is more efficent.
the surface design works like solid one, it creates surfaces by extrusion, by revolving, by sweep and by loft, filling sufaces with constraint boundary (curves, lines, vertex). Features to join and cut surfaces among them and make solid a close object
what do you think?
dxp.dev
Re: add to part design the "surface design"
Postby dxp.dev » Fri Dec 13, 2019 8:03 pm
Seems exactly what Additive tools and Subtractive tools do (https://www.freecadweb.org/wiki/PartDesign_Workbench/en)
Could you provide an example where those tools don't meet your needs and what would be the specificity of the surface modeling ?
That's what https://www.freecadweb.org/wiki/PartDesign_Boolean does.
Something like https://www.freecadweb.org/wiki/Draft_Upgrade but for 3D ?
Imperial system makes no sense, go metric ! ! !
Jee-Bee
Postby Jee-Bee » Mon Dec 16, 2019 7:19 am
There should be a surface module. check the addon manager
