Air Plane Design Workbench - discussion thread
unclesal
Re: Air Plane Design Workbench - discussion thread
Postby unclesal » Wed Oct 28, 2020 6:54 am
It seems that Qt 5.15 does not have module QtUiTools.
https://doc.qt.io/qt-5/qtmodules.html#qt-tools
sal@memo /usr/lib/python3.7/site-packages/PySide2 $ ls -la /usr/lib/python3.7/site-packages/PySide2
итого 33864
drwxr-xr-x   3 root root     4096 окт 27 19:42 .
drwxr-xr-x 419 root root    32768 окт 27 19:56 ..
-rw-r--r--   1 root root      296 окт 27 19:23 _config.py
-rw-r--r--   1 root root     2468 окт 27 19:23 _git_pyside_version.py
-rw-r--r--   1 root root     3544 окт 27 19:23 __init__.py
drwxr-xr-x   2 root root     4096 окт 27 19:41 __pycache__
-rwxr-xr-x   1 root root  4807504 окт 27 19:41 QtCore.cpython-37m-x86_64-linux-gnu.so
-rwxr-xr-x   1 root root  5280080 окт 27 19:41 QtGui.cpython-37m-x86_64-linux-gnu.so
-rwxr-xr-x   1 root root  1411048 окт 27 19:41 QtNetwork.cpython-37m-x86_64-linux-gnu.so
-rwxr-xr-x   1 root root 11083976 окт 27 19:41 QtOpenGLFunctions.cpython-37m-x86_64-linux-gnu.so
-rwxr-xr-x   1 root root   529520 окт 27 19:41 QtQml.cpython-37m-x86_64-linux-gnu.so
-rwxr-xr-x   1 root root   237456 окт 27 19:41 QtSvg.cpython-37m-x86_64-linux-gnu.so
-rwxr-xr-x   1 root root 10682480 окт 27 19:41 QtWidgets.cpython-37m-x86_64-linux-gnu.so
-rwxr-xr-x   1 root root   567792 окт 27 19:41 QtXml.cpython-37m-x86_64-linux-gnu.so
a179308
Postby a179308 » Wed Oct 28, 2020 7:38 am
Zolko wrote:
Tue Feb 04, 2020 1:35 pm
a179308 wrote:
Sun Jan 05, 2020 6:06 pm
I've have started a Air Plane Design Workbench
You can use this discussion thread to interact with me.
Hi, would this WB help in designing a rib construction wing ? Specifically, would it allow to make a geodesique (or geodetic ?) wing structure ?
Image Image
Hello
probably a good idea, but probably in a next release. I need to find enough time to finish the first iteration.
Fred
Pauvres_honteux
Postby Pauvres_honteux » Wed Oct 28, 2020 7:46 am
@a179308: will you work on Surface to surface tangency ?
I thought I'd ask since one must have that working when creating planes in particular.
jmcoursi
Postby jmcoursi » Mon Jan 18, 2021 9:40 am
I updated to the latest version of AirPlaneDesign (as of 2021/01/17, details at the end) and the Wing Wizard does not work anymore (the old "Create a Wing (old release)" does not work either. The simplest I can do to reproduce the pb :
- Create a new document
- Choose the AirPlaneDesign workbench
- Click Wing Wizard
- Click "Fill in Sheet with an example" and click OK
- The tree shows a RibRoot0 with a blue checkmark and nothing else. Nothing appears in the model view.
- The ReportView shows errors ":
-----------------Wing Wizard-----------------
09:23:11 Running the Python command 'airPlaneDesignWingWizard' failed:
File "C:\Users\JMC\AppData\Roaming\FreeCAD\Mod\AirPlaneDesign\airPlaneWingWizard.py", line 88, in Activated
WingRib(_ribs[i*2],_row[2],False,0,_row[3],_row[6],_position,_row[8],0,0,0)
File "C:\Users\JMC\AppData\Roaming\FreeCAD\Mod\AirPlaneDesign\airPlaneRib.py", line 72, in __init__
obj.Placement=FreeCAD.Placement(FreeCAD.Vector(_x,_y,_z), FreeCAD.Rotation(FreeCAD.Vector(_xrot,_yrot,_zrot),_rot))#, FreeCAD.Vector(0,0,0))
Either three floats, tuple or Vector expected
The Python console contains:
Python 3.8.6 | packaged by conda-forge | (default, Dec 26 2020, 04:30:06) [MSC v.1916 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> ### Begin command Std_New
>>> App.newDocument("Unnamed")
>>> # App.setActiveDocument("Unnamed")
>>> # App.ActiveDocument=App.getDocument("Unnamed")
>>> # Gui.ActiveDocument=Gui.getDocument("Unnamed")
>>> Gui.activeDocument().activeView().viewDefaultOrientation()
>>> ### End command Std_New
>>> Gui.runCommand('airPlaneDesignWingWizard',0)
I use Windows 10 Pro 64-bits, up to date (installed on 24/06/2020, build 19041.746)
and FreeCAD 0.19 :
OS: Windows 10 (10.0)
Version: 0.19.23546 (Git)
Hash: 6b017f9a16b15b0e628c8d874c4058442dee5548
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: French/France (fr_FR)
Merci, bonne journée !
-- Jean-Marc Coursimault
a179308
Postby a179308 » Sat Jan 23, 2021 3:27 pm
- Click Wing Wizard
and FreeCAD 0.19 :
Qt version: 5.12.5
OCC version: 7.4.0
Hi, Salut Jean Marc,
I fixed the bug on the old approach to create wing.
Fred
Ps : je te laisse vérifier si cela remarche....
a179308
Postby a179308 » Sat Jan 23, 2021 3:46 pm
as you can see I'm in the process of radically modifying the way of creating a wing. The new approach is based on a wing envelope and a path.
You can open the HawkerTempest2 file to test the approach, the process is as follows:
-select a wing: Wing
-select a rib: wrib002
-select the path: Wing-path
-select envelope: wing-envelope
click add wing panel
the result is visible in the file HawkerTempest2-complete :
Capture d’écran 2021-01-23 à 16.44.00.png (167.24 KiB) Viewed 98 times
It works on mac, i still have some adjustments left on windows, not tested on linux
there is still a lot of work to do before a fully usable version !
Fred
a179308
Postby a179308 » Sat Jan 23, 2021 3:48 pm
You can open the HawkerTempest2 file to test the approach, the process is :
the result is visible in the file HawkerTempest2-complete : Capture d’écran 2021-01-23 à 16.44.00.png.
It works on mac, I still have some adjustments left on windows, not tested on linux
Fred
a179308
Postby a179308 » Sat Jan 23, 2021 3:49 pm
Capture d’écran 2021-01-23 à 16.44.00.png (167.24 KiB) Viewed 94 times
Fred
jmcoursi
Postby jmcoursi » Sat Jan 23, 2021 8:07 pm
Fred
Works for me, thanks !
I tried to open the HawkerTempest2-complete.
I'm not sure why, but it is in C:\Users\JMC\AppData\Roaming\FreeCAD\Mod\AirPlaneDesign\examples and not in Documents/FreeCAD. Perhaps it's because I have both FC 0.18 and 0.19. Not a big deal.
Looks almost good. The only error is below :
21:00:01 ******* onChanged routine *********************
Change property: Twist
21:00:01 Just need an update of all Ribs
21:00:01 wingPanel : Execute function
21:00:01 update : True
21:00:01 Traceback (most recent call last):
File "C:\Users\JMC\AppData\Roaming\FreeCAD\Mod\AirPlaneDesign\airPlaneWPanel.py", line 306, in onChanged
self.execute(obj,True)
File "C:\Users\JMC\AppData\Roaming\FreeCAD\Mod\AirPlaneDesign\airPlaneWPanel.py", line 564, in execute
if not(self.obj.Ribs) :
<class 'AttributeError'>: 'WingPanel' object has no attribute 'obj'
Merci encore !
jmcoursi
Postby jmcoursi » Sat Jan 23, 2021 8:19 pm
Fred
Maybe a little pb at the junction of two wing panels ?
Courage (et merci !) ;)
