Frustrations with FreeCAD
openBrain
Re: Frustrations with FreeCAD
Postby openBrain » Tue Jan 28, 2020 4:47 pm
fmluizao wrote: ↑
Tue Jan 28, 2020 3:19 pm
Is there some good tutorial about this subject? Video, anything will be helpful :D
I can remember those previous examples :
https://forum.freecadweb.org/viewtopic. ... 73#p291421
https://forum.freecadweb.org/viewtopic. ... 10#p294532
The first applies expressions on Datum plane, but it works the same on sketches.
In the second link you have 2 different files in 2 following threads.
I think you can get good clues by analyzing the files and eventually reading the threads. Feel free to ask for details if needed. ;)
Postby chrisb » Tue Jan 28, 2020 6:26 pm
There is something between the prone-to-break attachment to faces and using expressions: You can reference sketches. A rather robust possibility is the aforementioned master sketch, but others can be referenced as well.
bejant
Postby bejant » Wed Jan 29, 2020 6:13 pm
Accessdenied wrote: ↑
Tue Jan 28, 2020 3:14 pm
What you mean by "you can place the Sketch by using Expressions" ?
As a simple example, instead of Mapping a Sketch onto the top face of a Pad you can use the Data tab > Property column > Attachment Offset > Position field, and use an Expression to locate the Sketch at Pad.Length. Or you can instead reference a Constraint in an earlier Sketch to locate a subsequent Sketch (you have to give the earlier Constraint a name first).
fmluizao wrote: ↑
I don't know off the top of my head but I'm sure there are others besides those that openBrain provided, you'll just have to search for them. (Maybe others can give a better answer than this one.)
Postby chrisb » Wed Jan 29, 2020 9:08 pm
I think Harra Geier's videos respect the placement without attaching to faces, IIRC his youtube name is HaGei.
jmaustpc
Postby jmaustpc » Thu Feb 13, 2020 9:26 am
This is a link to the Expressions page in the FreeCAD wiki
Expressions
