I have finally moved the first of our services to Digital Ocean. Part of this change involves moving from e.g. freecadweb.org/tracker to tracker.freecadweb.org. This should however be transparent as all existing links should work.
Ideally everything should be problem-free and significantly faster! If the first part is not quite right please post here to let me know so I can fix it ASAP.
Up next is the wiki.
