[Pattern Features enhancing] : circular and linear pattern must support also fillets and chamfers
realthunder
Re: [Pattern Features enhancing] : circular and linear pattern must support also fillets and chamfers
Postby realthunder » Thu Feb 13, 2020 8:47 am
Just realized that upstream PartDesign does not allow selecting dress up feature for patterning, so there will be no backward compatibility problem. Fine, I'll still leave SupportTransform property there for more configurability.
Postby chrisb » Thu Feb 13, 2020 9:00 am
Zolko wrote:
Thu Feb 13, 2020 8:43 am
Hold-on, shouldn't this be planned in a more organized way ?
You are right, although I don't think that the order of priorities is important. We can and should, of course, express wishes, but finally it is up to the developer (in this case realthunder) when it is done, and how it fits his overall development process.
But it definitely should be discussed how things are done, because it is much easier to do it right the first time, than changing things later.
one of those would be to be able to extrude (pad ?) a sketch up to a datum plane: today it's not possible.
Works here:
Snip macro screenshot-a4bd02.png (7.71 KiB) Viewed 268 times
OS: macOS High Sierra (10.13)
Version: 0.19.19541 (Git)
Hash: a797a4172709b82c6cd08dcf6df86cb789aaa3ce
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
UpToDatumPlane.FCStd
(9.57 KiB) Downloaded 4 times
realthunder
Postby realthunder » Thu Feb 13, 2020 9:04 am
Sure, but I prefer to discuss over something concrete. I won't insist on my way and my way only. I'll make something for everybody to try and then discuss up on.
For me, for example, the priority would rather be to correctly handle PartDesign::DatumThings, and one of those would be to be able to extrude (pad ?) a sketch up to a datum plane: today it's not possible.
That's separate feature quest. I don't think it conflicts with my multi-body plan in any way. I always take backward compatibility as the first priority,
Another big question is: how are Part, Body and Assemblies supposed to interact ? If PartDesign is orphaned code, and since you have spent quite some effort in making App::Part objects App::Link compatible, shouldn't the focus rather go towards the Part workbench ? It can mostly do the same things.
Yes, it can, but in quite different ways. I actually like the PartDesign way more (if implemented right), which is what most other CAD is doing too. As for the interaction with Assembly, my asm3 container is designed without restriction on what type of objects it can contain. The constraining element is abstracted using special type of object that accepts almost any thing. I am not saying that FC's future assembly container should work like this, but it certainly shows that it is possible to keep developing PartDesign now without worrying too much about the assembly.
Postby chrisb » Thu Feb 13, 2020 9:10 am
UpToDatumPlane works in 0.18.4 as well.
openBrain
Postby openBrain » Thu Feb 13, 2020 9:34 am
Works for quite a long time => https://forum.freecadweb.org/viewtopic. ... 17#p313150
Zolko
Postby Zolko » Thu Feb 13, 2020 11:12 am
ah good to know, I hadn't checked recently.
uwestoehr
Postby uwestoehr » Thu Feb 13, 2020 11:27 am
I have one: on my personal Todo list I have an issue that I would like to fix but need a starting point where to look in the code:
- assume you have a cube, then you can select e.g. 5 of its edges and then use the menu PartDesign -> Fillet
result: you get immediately a fillet on all 5 selected edges
- no you have already a document with fillets and you realize that you must fillet e.g. 5 more edges using the same fillet parameters. Therefore you open the existing fillet but then you can only add one edge after another. This is very time consuming (in real life I deal with dozens of filleted edges on every part).
So what I simply want to do is to add the functionality to the fillet dialog to select multiple edged to add them to the fillet.
jaisejames
Postby jaisejames » Thu Feb 13, 2020 11:35 am
My feature request for part design
* Add Taper outward angle option part design extrude also [now available part extrude].
* Add extrude up to faces if more than one face come [same can be done part with join -> connect objects].
dxp.dev
Postby dxp.dev » Thu Feb 13, 2020 1:07 pm
That is an excellent thing to do ! I hope you will be able to do that, as it will simplify the workflow for virtually every user of FC :!:
Imperial system makes no sense, go metric ! ! !
Postby chrisb » Thu Feb 13, 2020 2:44 pm
That's a very good plan! This has been discussed already several times and noone seemed to be very happy with it. Equally or even more cumbersome is the selection mechanism for the patternshaving more than one feature.
If you want to work on that, please have a look at the Path workbench, where a rather smooth selection mechanism has been implemented.
