Fillets and old iron
drmacro
Postby drmacro » Sat Feb 22, 2020 4:14 pm
I mentioned in a post the other day that I was working through exercises in an old drafting text.
I saw this one and thought it would give filleting a hard time...I was right. 8-)
I've attempted this in Part Design only, mixed Part/Part Design (i.e. think base features), and Part only.
I've been unable to get all the fillets.
I'm willing to be proven wrong. :!: :lol:
OS: Ubuntu 19.10 (XFCE/ubuntustudio)
Version: 0.19.
Python version: 3.7.5
Qt version: 5.12.4
Fig_6-91-3.FCStd
Latest attempt, Part WB only
(61.04 KiB) Downloaded 11 times
My beginners, written treatise: Learning FreeCAD
carlopav
Re: Fillets and old iron
Postby carlopav » Sat Feb 22, 2020 5:00 pm
I think much of the problem with fillets it's here:
You can set different fillets for every edge, so you have enough surface to be filleted.
EDIT: also you can treat every fillet at the end and not include some of them in the sketches.
Fig_6-91-3.FCStd
(49.19 KiB) Downloaded 10 times
drmacro
Postby drmacro » Sat Feb 22, 2020 6:10 pm
Everything you said.
But, the reason that I attempted to do it along the way (in that attempt) was, doing the fillets at the end literally crashed FC. :o
In addition, different fillet radii can be used...but, would not complete the exercise as prescribed. I.e. the note: "FILLETS & ROUNDS 1/8 R" 8-)
If you look close, I even fudged the area you highlight by making the extrusion extend past the flange of the revolve. To avoid sliver faces where the flange revolve meets the pad. ;)
bejant
Postby bejant » Sat Feb 22, 2020 7:47 pm
When that textbook was written the mold pattern would have been made by hand from wood and the outside corner fillets abraded away (file, sandpaper) and the inside corner fillets made by filing them in with a bead of some material that hardened afterwards.
I don't think that directly trying to model the piece in the as-machined condition can produce a proper model. Instead, I think that the un-machined casting should be modeled, and once that raw casting is complete, the machined holes and flats should be pocketed away.
Even so, I don't think the 2D drawing is a true representation of the 3D part, especially at the back where the fillets on the vertical side faces meet the curve flange thickness and at the front where the machined face meets the flange corner fillets. (Quick61 had a word or phrase for that type of visual hocus-pocus but I don't remember what it was).
tanderson69
Postby tanderson69 » Sun Feb 23, 2020 3:38 am
opencascade can do it with the proper amount of swearing. I had the most trouble in the front area without the boss.
bejant
Postby bejant » Sun Feb 23, 2020 3:48 am
Wow ! Looks nicely done - can you post the file?
tanderson69
Postby tanderson69 » Sun Feb 23, 2020 4:39 am
I used opencascade, but not freecad. So all I can give you is a brep. If you want to know how I did something specific, just ask.
oldIronBlobfishRev03.brep
(375.35 KiB) Downloaded 14 times
carlopav
Postby carlopav » Sun Feb 23, 2020 11:40 am
What does I mean exactly? Sorry but I'm very curious...
user1234
Postby user1234 » Sun Feb 23, 2020 11:59 am
Just for testing. Works without problems here (PartDesign). But i was expecting errors on the corner (like other CADs) so i the way i model it was a little different (like i do when i see corners like that). You can model it much easier (treestructure) but for me it is ok. I rounded all measures in metric.
Greetings
info:
OS: Debian GNU/Linux 10 (buster) (X-Cinnamon/lightdm-xsession)
Version: 0.19.19524 (Git)
Hash: 045e924cd6ef35f03c59ab5dbd07ad9e78508482
Python version: 3.7.3
Qt version: 5.11.3
OCC version: 7.4.0
test.FCStd
(417.27 KiB) Downloaded 11 times
carlopav
Postby carlopav » Sun Feb 23, 2020 1:00 pm
Great! this would be a nice tutorial btw
