Mantis: tracker goes offline and Source Integration misses commits
Observation: when the tracker goes offline for some reason so does the capability for the source integration plugin to track the GitHub repository. I guess this is the reason why when I try to link certain tickets in Mantis to their corresponding GitHub commits, it's not possible.
I'm imagining that the commit is not available within the source integration database due to the lapse in connection. Does that sound right? And is there a way that we can keep the source integration updated in spite of this?
Edit: see issue #4276
Re: Mantis: tracker goes offline and Source Integration misses commits
Seems source integration isn't working
https://tracker.freecadweb.org/view.php?id=4087#c14213
- kkremitzki
I increased the number of php-fpm workers and manually ran the import script, please let me know if that helped.
I think manually re-running the import script worked for sure. thanks! I guess that should be part of a workflow, if the tracker goes offline or something?kkremitzki wrote: ↑Sat Mar 07, 2020 3:36 am I increased the number of php-fpm workers and manually ran the import script, please let me know if that helped.
- kkremitzki
My hope is that increasing the number of workers takes care of it in the future, keep an eye out for it happening again and we can try to narrow down the cause if it does reoccur.
Is there still issue with Source Integration plugin ?
It misses eg. this 2 commits : Thanks
- kkremitzki
I just re-ran a manual import. Please let me know if there are still any problems after this so I can try to isolate the cause when/if they reappear.
Thanks. I'll keep an eye open and will post to this thread (if i can find it again LOL )kkremitzki wrote: ↑Sun Mar 22, 2020 10:23 pm I just re-ran a manual import. Please let me know if there are still any problems after this so I can try to isolate the cause when/if they reappear.
Happened again:kkremitzki wrote: ↑Sun Mar 22, 2020 10:23 pm I just re-ran a manual import. Please let me know if there are still any problems after this so I can try to isolate the cause when/if they reappear.
https://tracker.freecadweb.org/view.php?id=4254#c14283
- kkremitzki
Strange, the server itself didn't go down and I didn't do anything myself either... that points to this being a sporadic issue though which is what I was suspecting.
