How much interest is there to integrate LibreOffice into FreeCAD?
- microelly2
Re: How much interest is there to integrate LibreOffice into FreeCAD?
It is nice to see how it will work.
There is no hurry for me at the moment, but keep us uptodate.
There is realy an interest to to have this exchange.
Another usecase for this endeavor: issue #2957: 'please add spreadsheet direct printing'
**** this only works in linux ***
I updated the fc_libre macro to utilize the open file dialog box.
The macros should:
The macro is a little buggy when starting soffice, it behaves differently on the first start.
Thanks
The macros should:
- Open a dialog to get the existing calc document
start the soffice app as a process and listen on port 2002
open the spreadsheet file
write to cell A1 and B2
Thanks
Where and what version of uno should I install?
Kunda1,
The dependencies are:
Python v3.x
python3-uno
pyoo
you can install these from the command line:
"sudo apt-get install python3-uno"
"python3 -m pip3 install pyoo"
EDIT:
Almost forgot, I'm assuming you have a recent version of LibreOffice or OpenOffice installed.
Python v3.x
python3-uno
pyoo
EDIT:
Updated the code in fc_libre.FCMacro
The new code gets the currently selected freecad object and attempts to iterate its sub elements and writing the content in the spreadsheet (well that's the idea anyway)
Note:
There is a 10 to 15 second delay when the code opens the spreadsheet document, looking into it.
If anyone knows how to setup a code development environment, please point me in the right direction.
It seems that I cannot debug in traditional IDE because it does not see the FreeCAD code and AFAIK there is no development module built into FreeCAD.
Thanks
Sal
Note:
fileOp = FileIo()
>> ## delay is here
fileName = fileOp.openFile()
Thanks
Sal
fc_libre.FCMacro
dependencies
Linux OS
python3-uno
pyoo
Well were making some progress:
Changed how soffice process is started, to make sure we are connecting to the correct process.
What it can do sofar:
Next steps
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
dependencies
Linux OS
python3-uno
pyoo
- the code checks if the process is already running
if the process is running it is shutdown
a new soffice process is started connected to port 2002
- starts the soffice process set to listen on port 2002
opens libreOffice file dilaog window and waits for file selection
attaches to "Sheet1"
Writes text to the cell "A1"
gets the freecad active document info
write the active file info to the spreasheet.
Next steps
- Iterate the current object and copy its data to the spreadsheet
* I'm learning both Python anf FreeCAD scripting at the same time, so this will move slowly
* Any scripting tips are appreciated
Version: 0.19.
Qt version: 5.9.5
Nice to see some progress with this project. When you have a Windows and MacOS working version please let-me know.
Nice, do you mind adding a screencast of the progress when you post? It really helps to see it visually and it definitely generates more interestsalp wrote: ↑Sun Mar 22, 2020 1:47 am What it can do sofar:
I've not done that before, but I'll give it a try.
I uploaded a video to youtube.
