AppImage - Include auto-updating logic in to appimage directly?
Postby Kunda1 » Thu Mar 19, 2020 1:27 pm
Name: Consider making the AppImage self-updatable from the menu
Ticket: https://github.com/FreeCAD/FreeCAD-AppImage/issues/27
Repo: https://github.com/antony-jr/AppImageUpdaterBridge
Note: this ticket was opened by @probonopd who developed the whole AppImage idea.
How do we do this?
The README says it's testable in this code:
#include <QCoreApplication>
#include <AppImageUpdaterBridge>
int main(int argc, char **argv)
    using AppImageUpdaterBridge::AppImageDeltaRevisioner;
    QCoreApplication app(argc, argv);
    AppImageDeltaRevisioner DeltaRevisioner;
    QObject::connect(&DeltaRevisioner, &AppImageDeltaRevisioner::finished, &app, &QCoreApplication::quit);
    DeltaRevisioner.setShowLog(true); // Display logs?
    DeltaRevisioner.start();
    return app.exec();
looo
Re: AppImage - Include auto-updating logic in to appimage directly?
Postby looo » Thu Mar 19, 2020 1:55 pm
Are there python bindings? I don't think we should make the source dependent on appimage-libraray (also not optional) and also we shouldn't make the package dependent on the appimage-library. I guess it's best to write an extension that adds the updating-process and install this extension during the appimage creation.
triplus
Postby triplus » Fri Mar 20, 2020 2:08 pm
I left a note on GitHub.
P.S. In short i feel that people using AppImages can handle a drag and drop operation just fine, for updating. And that already is an elegant and easy solution without introducing any additional maintenance burden and potential issues.
Postby Kunda1 » Fri Mar 20, 2020 2:15 pm
See https://github.com/FreeCAD/FreeCAD-AppI ... -601215162 (the Edit part)
triplus
Postby triplus » Fri Mar 20, 2020 5:20 pm
I added an additional note on GitHub. Basically what we could do for now is to i guess package the library on Conda and hence include it in the AppImage (next development oriented AppImage). People could play with it after, from FreeCAD Python console. If anything comes out of it, like FreeCAD command providing a frontend, great, if not, just continue to use one of the AppImage updater tools available out there.
P.S. If we don't do that, and just continue to redirect people to using existing external updating tools, that is fine with me too.
Postby Kunda1 » Sat Mar 21, 2020 4:53 pm
:+1:
looo
Postby looo » Sat Mar 21, 2020 8:01 pm
recipe: https://github.com/FreeCAD/FreeCAD_Cond ... /meta.yaml
package: https://anaconda.org/freecad/appimage-u ... idge/files
but I am not sure how to build python bindings. Anyone familiar with shiboken? sry didn't see the link @kunda posted.
antonyjr
Postby antonyjr » Sat Mar 21, 2020 9:40 pm
Thank you for creating the package.
The problem with the build is that you are using the stable version 1.1.6 which does not implement the interface for Qt plugin loader, The implementation is still in alpha and it is present in the plugin branch of the git repo. If possible, please use that branch to build the package to test out the plugin feature.
Also only the qmake project file has the logic to build it has a plugin.
looo
Postby looo » Sun Mar 22, 2020 6:36 am
I see.
Any chance to add the plugin logic to cmake? qmake is a pain with conda-build (at least for me).
antonyjr
Postby antonyjr » Sun Mar 22, 2020 4:10 pm
@looo sure I can. Just wait a bit, I will release all the documentation and also the instruction to build the plugin with cmake ASAP.
