AppImage - Include auto-updating logic in to appimage directly?
Re: AppImage - Include auto-updating logic in to appimage directly?
AppImage Updated successfully from Preferences control panel UI!
Thanks for sticking with FreeCAD looo!
- adrianinsaval
This doesn't work for me
Please add what this means. Still the same message as above?
I tested the latest state (21514) and it worked for me. Only problem I have seen so far: If "always check for updates" is enabled the log is also shown when no new appimage is available which is not by design.
- adrianinsaval
Yes, I still get the same message. What conditions does it need to work?
I can confirm that the updateprocess within freecad does not work if you use the appimageLauncher. Maybe @antonyjr can give some insights.adrianinsaval wrote: ↑Thu Jun 04, 2020 7:43 pm I get this message when checking for updates:Code: Select all
loading the plugin: True INFO: setAppImage : "/run/user/1000/appimagelauncherfs/0002.AppImage" . FATAL: getInfo : invalid magic bytes( 127 , 69 ).
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.21329 (Git) AppImage
Hash: 2330eef823b32ac412d839031cc174353a76b013
Python version: 3.8.2
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: Spanish/Paraguay (es_PY)
Same here:
OS: Ubuntu 20.04 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.21514 (Git) AppImage
Hash: 89ddab33f692a9bd739171689f9ab0eb58d64b35
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
INFO: setAppImage : "/run/user/1000/appimagelauncherfs/0001.AppImage" .
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Regards / Viele Grüße
Max
Max
Can confirm that the update feature for appimage doesn't work on
OS: Manjaro Linux (XFCE/xfce)
Version: 0.19.21622 (Git) AppImage
Hash: f5a5bf7900e9a5cdbb5f7f82fcf5123b27c9703f
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Edit: Added screencast
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
I guess this is a different kind of issue and related to the theme. Somehow the button is not displayed. Maybe I should create the buttons all manually and not combine a QDialogButtonBox with an additional button. Let's try this:
https://github.com/looooo/freecad.appim ... c3c6424762
