Then I opened up many workbenches to get their commands loaded and ran this macro:
AlignerTools-->None
Arch_3Views-->None
Arch_Add-->None
Arch_Axis-->A, X
Arch_AxisSystem-->X, S
Arch_AxisTools-->None
Arch_Building-->B, U
Arch_BuildingPart-->B, P
Arch_Check-->None
Arch_CloneComponent-->C, C
Arch_CloseHoles-->None
Arch_Component-->C, M
Arch_CutLine-->None
Arch_CutPlane-->None
Arch_Equipment-->E, Q
Arch_Fence-->None
Arch_Floor-->L, V
Arch_Frame-->F, R
Arch_Grid-->A, X
Arch_IfcSpreadsheet-->I, P
Arch_Material-->M, T
Arch_MaterialTools-->None
Arch_MergeWalls-->None
Arch_MeshToShape-->None
Arch_MultiMaterial-->M, T
Arch_Nest-->N, E
Arch_Panel-->P, A
Arch_PanelTools-->None
Arch_Panel_Cut-->P, C
Arch_Panel_Sheet-->P, S
Arch_Pipe-->P, I
Arch_PipeConnector-->P, C
Arch_PipeTools-->None
Arch_Project-->P, O
Arch_Rebar-->R, B
Arch_Reference-->E, X
Arch_Remove-->None
Arch_RemoveShape-->None
Arch_Roof-->R, F
Arch_Schedule-->None
Arch_SectionPlane-->S, E
Arch_SelectNonSolidMeshes-->None
Arch_Site-->S, I
Arch_Space-->S, P
Arch_SplitMesh-->None
Arch_Stairs-->S, R
Arch_Structure-->S, T
Arch_Survey-->None
Arch_ToggleIfcBrepFlag-->None
Arch_ToggleSubs-->Ctrl+Space
Arch_Wall-->W, A
Arch_Window-->W, N
CaliperTools-->None
DF_SelectLoop-->None
DefeatShapeFeature-->None
DefeaturingTools-->None
Draft_AddConstruction-->None
Draft_AddToGroup-->None
Draft_ApplyStyle-->None
Draft_Arc-->A, R
Draft_ArcTools-->None
Draft_Arc_3Points-->A,T
Draft_Array-->None
Draft_ArrayTools-->None
Draft_AutoGroup-->None
Draft_BSpline-->B, S
Draft_BezCurve-->B, Z
Draft_BezierTools-->None
Draft_Circle-->C, I
Draft_CircularArray-->None
Draft_Clone-->C,L
Draft_CloseLine-->None
Draft_CubicBezCurve-->None
Draft_Dimension-->D, I
Draft_Downgrade-->D, N
Draft_Draft2Sketch-->None
Draft_Drawing-->D, D
Draft_Edit-->D, E
Draft_Ellipse-->E, L
Draft_Facebinder-->F,F
Draft_Fillet-->None
Draft_FinishLine-->None
Draft_FlipDimension-->None
Draft_Heal-->None
Draft_Join-->J, O
Draft_Label-->D, L
Draft_Layer-->None
Draft_Line-->L,I
Draft_LinkArray-->None
Draft_Mirror-->M, I
Draft_Move-->M, V
Draft_Offset-->O, S
Draft_OrthoArray-->None
Draft_PathArray-->None
Draft_PathLinkArray-->None
Draft_Point-->None
Draft_PointArray-->None
Draft_PolarArray-->None
Draft_Polygon-->P, G
Draft_Rectangle-->R, E
Draft_Rotate-->R, O
Draft_Scale-->S, C
Draft_SelectGroup-->None
Draft_SelectPlane-->W, P
Draft_SetWorkingPlaneProxy-->None
Draft_Shape2DView-->None
Draft_ShapeString-->S, S
Draft_ShowSnapBar-->None
Draft_Slope-->None
Draft_Snap_Angle-->None
Draft_Snap_Center-->None
Draft_Snap_Dimensions-->None
Draft_Snap_Endpoint-->None
Draft_Snap_Extension-->None
Draft_Snap_Grid-->None
Draft_Snap_Intersection-->None
Draft_Snap_Lock-->Shift+S
Draft_Snap_Midpoint-->None
Draft_Snap_Near-->None
Draft_Snap_Ortho-->None
Draft_Snap_Parallel-->None
Draft_Snap_Perpendicular-->None
Draft_Snap_Special-->None
Draft_Snap_WorkingPlane-->None
Draft_Split-->S, P
Draft_Stretch-->S, H
Draft_SubelementHighlight-->H, S
Draft_Text-->T, E
Draft_ToggleConstructionMode-->C, M
Draft_ToggleContinueMode-->None
Draft_ToggleDisplayMode-->Shift+Space
Draft_ToggleGrid-->G,R
Draft_Trimex-->T, R
Draft_UndoLine-->None
Draft_Upgrade-->U, P
Draft_Wire-->P, L
Draft_WireToBSpline-->None
FuzzyCommon-->None
FuzzyCut-->None
FuzzyUnion-->None
Image_CreateImagePlane-->None
Image_Open-->None
Image_Scaling-->None
Lattice2_PDPattern-->None
Manipulator-cheat-sheet.pdf-->None
Mesh_AddFacet-->None
Mesh_BoundingBox-->None
Mesh_BuildRegularSolid-->None
Mesh_CrossSections-->None
Mesh_CurvatureInfo-->None
Mesh_Difference-->None
Mesh_EvaluateFacet-->None
Mesh_EvaluateSolid-->None
Mesh_Evaluation-->None
Mesh_Export-->None
Mesh_FillInteractiveHole-->None
Mesh_FillupHoles-->None
Mesh_FlipNormals-->None
Mesh_FromGeometry-->None
Mesh_FromPartShape-->None
Mesh_HarmonizeNormals-->None
Mesh_Import-->None
Mesh_Intersection-->None
Mesh_Merge-->None
Mesh_PolyCut-->None
Mesh_PolySegm-->None
Mesh_PolySplit-->None
Mesh_PolyTrim-->None
Mesh_RemeshGmsh-->None
Mesh_RemoveCompByHand-->None
Mesh_RemoveComponents-->None
Mesh_Scale-->None
Mesh_SectionByPlane-->None
Mesh_Segmentation-->None
Mesh_SegmentationBestFit-->None
Mesh_Smoothing-->None
Mesh_TrimByPlane-->None
Mesh_Union-->None
Mesh_VertexCurvature-->None
MoverTools-->None
OpenSCAD_AddOpenSCADElement-->None
OpenSCAD_ColorCodeShape-->None
OpenSCAD_Edgestofaces-->None
OpenSCAD_ExpandPlacements-->None
OpenSCAD_ExplodeGroup-->None
OpenSCAD_Hull-->None
OpenSCAD_IncreaseToleranceFeature-->None
OpenSCAD_MeshBoolean-->None
OpenSCAD_Minkowski-->None
OpenSCAD_RefineShapeFeature-->None
OpenSCAD_RemoveSubtree-->None
OpenSCAD_ReplaceObject-->None
PartDesign_AdditiveLoft-->None
PartDesign_AdditivePipe-->None
PartDesign_Body-->None
PartDesign_Boolean-->None
PartDesign_Chamfer-->None
PartDesign_Clone-->None
PartDesign_CompPrimitiveAdditive-->None
PartDesign_CompPrimitiveSubtractive-->None
PartDesign_CoordinateSystem-->None
PartDesign_Draft-->None
PartDesign_DuplicateSelection-->None
PartDesign_Fillet-->None
PartDesign_Groove-->None
PartDesign_Hole-->None
PartDesign_InvoluteGear-->None
PartDesign_Line-->None
PartDesign_LinearPattern-->None
PartDesign_Migrate-->None
PartDesign_Mirrored-->None
PartDesign_MoveFeature-->None
PartDesign_MoveFeatureInTree-->None
PartDesign_MoveTip-->None
PartDesign_MultiTransform-->None
PartDesign_NewSketch-->None
PartDesign_Pad-->None
PartDesign_Plane-->None
PartDesign_Pocket-->None
PartDesign_Point-->None
PartDesign_PolarPattern-->None
PartDesign_Revolution-->None
PartDesign_ShapeBinder-->None
PartDesign_SubShapeBinder-->None
PartDesign_SubtractiveLoft-->None
PartDesign_SubtractivePipe-->None
PartDesign_Thickness-->None
Part_Boolean-->None
Part_BooleanFragments-->None
Part_Box-->None
Part_BoxSelection-->None
Part_Builder-->None
Part_Chamfer-->None
Part_CheckGeometry-->None
Part_ColorPerFace-->None
Part_Common-->None
Part_CompCompoundTools-->None
Part_CompJoinFeatures-->None
Part_CompOffset-->None
Part_CompSplitFeatures-->None
Part_Compound-->None
Part_CompoundFilter-->None
Part_Cone-->None
Part_CrossSections-->None
Part_Cut-->None
Part_Cylinder-->None
Part_Defeaturing-->None
Part_EditAttachment-->None
Part_ElementCopy-->None
Part_ExplodeCompound-->None
Part_Export-->None
Part_Extrude-->None
Part_Fillet-->None
Part_Fuse-->None
Part_Import-->None
Part_ImportCurveNet-->None
Part_JoinConnect-->None
Part_JoinCutout-->None
Part_JoinEmbed-->None
Part_Loft-->None
Part_MakeFace-->None
Part_MakeSolid-->None
Part_MakeTube-->None
Part_Measure_Angular-->None
Part_Measure_Clear_All-->None
Part_Measure_Linear-->None
Part_Measure_Refresh-->None
Part_Measure_Toggle_3d-->None
Part_Measure_Toggle_All-->None
Part_Measure_Toggle_Delta-->None
Part_Mirror-->None
Part_Offset-->None
Part_Offset2D-->None
Part_PickCurveNet-->None
Part_PointsFromMesh-->None
Part_Primitives-->None
Part_RefineShape-->None
Part_ReverseShape-->None
Part_Revolve-->None
Part_RuledSurface-->None
Part_Section-->None
Part_ShapeFromMesh-->None
Part_ShapeInfo-->None
Part_SimpleCopy-->None
Part_SimpleCylinder-->None
Part_Slice-->None
Part_SliceApart-->None
Part_Sphere-->None
Part_Sweep-->None
Part_Thickness-->None
Part_Torus-->None
Part_TransformedCopy-->None
Part_XOR-->None
Part_projectionOnSurface-->None
Path_Adaptive-->None
Path_Area-->None
Path_Area_Workplane-->None
Path_Array-->None
Path_Comment-->None
Path_Compound-->None
Path_Contour-->None
Path_Custom-->None
Path_Deburr-->None
Path_DressupAxisMap-->None
Path_DressupDogbone-->None
Path_DressupDragKnife-->None
Path_DressupLeadInOut-->None
Path_DressupPathBoundary-->None
Path_DressupRampEntry-->None
Path_DressupTag-->None
Path_DressupZCorrect-->None
Path_Drilling-->None
Path_Engrave-->None
Path_EngraveTools-->None
Path_ExportTemplate-->None
Path_Fixture-->None
Path_Helix-->None
Path_Hop-->None
Path_Inspect-->P, I
Path_Job-->P, J
Path_MillFace-->None
Path_OpActiveToggle-->P, X
Path_OperationCopy-->None
Path_Pocket_3D-->None
Path_Pocket_Shape-->None
Path_Post-->P, P
Path_Probe-->None
Path_Profile_Edges-->None
Path_Profile_Faces-->None
Path_Sanity-->P, S
Path_SelectLoop-->P, L
Path_SetStartPoint-->None
Path_Shape-->None
Path_SimpleCopy-->None
Path_Simulator-->P, M
Path_Stop-->None
Path_ToolBitCreate-->None
Path_ToolBitLibraryLoad-->None
Path_ToolBitLibraryOpen-->None
Path_ToolBitLoad-->None
Path_ToolBitSave-->None
Path_ToolBitSaveAs-->None
Path_ToolController-->None
Path_ToolLibraryEdit-->P, T
Robot_AddToolShape-->None
Robot_Create-->None
Robot_CreateTrajectory-->None
Robot_Edge2Trac-->None
Robot_ExportKukaCompact-->None
Robot_ExportKukaFull-->None
Robot_InsertKukaIR125-->None
Robot_InsertKukaIR16-->None
Robot_InsertKukaIR210-->None
Robot_InsertKukaIR500-->None
Robot_InsertWaypoint-->A
Robot_InsertWaypointPreselect-->W
Robot_RestoreHomePos-->None
Robot_SetDefaultOrientation-->None
Robot_SetDefaultValues-->None
Robot_SetHomePos-->None
Robot_Simulate-->None
Robot_TrajectoryCompound-->None
Robot_TrajectoryDressUp-->None
Sketcher_BSplineComb-->None
Sketcher_BSplineConvertToNURB-->None
Sketcher_BSplineDecreaseKnotMultiplicity-->None
Sketcher_BSplineDegree-->None
Sketcher_BSplineIncreaseDegree-->None
Sketcher_BSplineIncreaseKnotMultiplicity-->None
Sketcher_BSplineKnotMultiplicity-->None
Sketcher_BSplinePolygon-->None
Sketcher_CarbonCopy-->C,C
Sketcher_Clone-->None
Sketcher_CloseShape-->CTRL+SHIFT+S
Sketcher_CompBSplineShowHideGeometryInformation-->None
Sketcher_CompConstrainRadDia-->SHIFT+R
Sketcher_CompCopy-->CTRL+C
Sketcher_CompCreateArc-->None
Sketcher_CompCreateBSpline-->None
Sketcher_CompCreateCircle-->None
Sketcher_CompCreateConic-->None
Sketcher_CompCreateRegularPolygon-->None
Sketcher_CompModifyKnotMultiplicity-->None
Sketcher_ConnectLines-->CTRL+SHIFT+K
Sketcher_ConstrainAngle-->A
Sketcher_ConstrainBlock-->None
Sketcher_ConstrainCoincident-->C
Sketcher_ConstrainDiameter-->None
Sketcher_ConstrainDistance-->SHIFT+D
Sketcher_ConstrainDistanceX-->SHIFT+H
Sketcher_ConstrainDistanceY-->SHIFT+V
Sketcher_ConstrainEqual-->E
Sketcher_ConstrainHorizontal-->H
Sketcher_ConstrainInternalAlignment-->Ctrl+A
Sketcher_ConstrainLock-->None
Sketcher_ConstrainParallel-->SHIFT+P
Sketcher_ConstrainPerpendicular-->N
Sketcher_ConstrainPointOnObject-->SHIFT+O
Sketcher_ConstrainRadius-->None
Sketcher_ConstrainSnellsLaw-->None
Sketcher_ConstrainSymmetric-->S
Sketcher_ConstrainTangent-->T
Sketcher_ConstrainVertical-->V
Sketcher_Copy-->None
Sketcher_Create3PointArc-->None
Sketcher_Create3PointCircle-->None
Sketcher_CreateArc-->None
Sketcher_CreateArcOfEllipse-->None
Sketcher_CreateArcOfHyperbola-->None
Sketcher_CreateArcOfParabola-->None
Sketcher_CreateBSpline-->None
Sketcher_CreateCircle-->None
Sketcher_CreateEllipseBy3Points-->None
Sketcher_CreateEllipseByCenter-->None
Sketcher_CreateFillet-->F
Sketcher_CreateHeptagon-->None
Sketcher_CreateHexagon-->None
Sketcher_CreateLine-->L
Sketcher_CreateOctagon-->None
Sketcher_CreatePentagon-->None
Sketcher_CreatePeriodicBSpline-->None
Sketcher_CreatePoint-->None
Sketcher_CreatePolyline-->None
Sketcher_CreateRectangle-->R
Sketcher_CreateRegularPolygon-->None
Sketcher_CreateSlot-->None
Sketcher_CreateSquare-->None
Sketcher_CreateTriangle-->None
Sketcher_DeleteAllConstraints-->None
Sketcher_DeleteAllGeometry-->None
Sketcher_EditSketch-->None
Sketcher_Extend-->T,E
Sketcher_External-->X
Sketcher_LeaveSketch-->None
Sketcher_MapSketch-->None
Sketcher_MergeSketches-->None
Sketcher_MirrorSketch-->None
Sketcher_Move-->CTRL+M
Sketcher_NewSketch-->None
Sketcher_ProfilesHexagon1-->None
Sketcher_RectangularArray-->None
Sketcher_ReorientSketch-->None
Sketcher_RestoreInternalAlignmentGeometry-->CTRL+SHIFT+E
Sketcher_SelectConflictingConstraints-->CTRL+SHIFT+E
Sketcher_SelectConstraints-->CTRL+SHIFT+C
Sketcher_SelectElementsAssociatedWithConstraints-->CTRL+SHIFT+E
Sketcher_SelectElementsWithDoFs-->None
Sketcher_SelectHorizontalAxis-->CTRL+SHIFT+H
Sketcher_SelectOrigin-->CTRL+SHIFT+O
Sketcher_SelectRedundantConstraints-->CTRL+SHIFT+R
Sketcher_SelectVerticalAxis-->CTRL+SHIFT+V
Sketcher_StopOperation-->None
Sketcher_SwitchVirtualSpace-->None
Sketcher_Symmetry-->None
Sketcher_ToggleActiveConstraint-->None
Sketcher_ToggleConstruction-->C,M
Sketcher_ToggleDrivingConstraint-->None
Sketcher_Trimming-->T,R
Sketcher_ValidateSketch-->None
Sketcher_ViewSection-->None
Sketcher_ViewSketch-->None
Spreadsheet_AlignBottom-->None
Spreadsheet_AlignCenter-->None
Spreadsheet_AlignLeft-->None
Spreadsheet_AlignRight-->None
Spreadsheet_AlignTop-->None
Spreadsheet_AlignVCenter-->None
Spreadsheet_CreateSheet-->None
Spreadsheet_Export-->None
Spreadsheet_Import-->None
Spreadsheet_MergeCells-->None
Spreadsheet_SetAlias-->Ctrl+Shift+A
Spreadsheet_SplitCell-->None
Spreadsheet_StyleBold-->None
Spreadsheet_StyleItalic-->None
Spreadsheet_StyleUnderline-->None
Std_About-->None
Std_AboutQt-->None
Std_ActivateNextWindow-->Ctrl+Tab
Std_ActivatePrevWindow-->Ctrl+Shift+Backtab
Std_AddonMgr-->None
Std_Alignment-->None
Std_ArrangeIcons-->None
Std_AxisCross-->None
Std_BoxElementSelection-->Shift+E
Std_BoxSelection-->Shift+B
Std_CascadeWindows-->None
Std_CloseActiveWindow-->Ctrl+W
Std_CloseAllWindows-->None
Std_CommandLine-->None
Std_Copy-->Ctrl+C
Std_Cut-->Ctrl+X
Std_Delete-->Del
Std_DemoMode-->None
Std_DlgCustomize-->None
Std_DlgMacroExecute-->None
Std_DlgMacroExecuteDirect-->Ctrl+F6
Std_DlgMacroRecord-->None
Std_DlgParameter-->None
Std_DlgPreferences-->None
Std_DockViewMenu-->None
Std_DrawStyle-->None
Std_DuplicateSelection-->None
Std_Edit-->None
Std_Export-->Ctrl+E
Std_ExportGraphviz-->None
Std_Expressions-->None
Std_FreeCADFAQ-->None
Std_FreeCADForum-->None
Std_FreeCADPowerUserHub-->None
Std_FreeCADUserHub-->None
Std_FreeCADWebsite-->None
Std_FreezeViews-->Shift+F
Std_Group-->None
Std_HideObjects-->None
Std_HideSelection-->None
Std_Import-->Ctrl+I
Std_LinkActions-->None
Std_LinkImport-->None
Std_LinkImportAll-->None
Std_LinkMake-->None
Std_LinkMakeGroup-->None
Std_LinkMakeRelative-->None
Std_LinkReplace-->None
Std_LinkSelectActions-->None
Std_LinkSelectAllLinks-->None
Std_LinkSelectLinked-->S, G
Std_LinkSelectLinkedFinal-->S, D
Std_LinkUnlink-->None
Std_MDITest1-->None
Std_MDITest2-->None
Std_MDITest3-->None
Std_MacroAttachDebugger-->None
Std_MacroStartDebug-->F6
Std_MacroStepInto-->F11
Std_MacroStepOver-->F10
Std_MacroStopDebug-->Shift+F6
Std_MacroStopRecord-->None
Std_Macro_0-->none
Std_Macro_1-->tidak ada
Std_Macro_2-->?
Std_Macro_3-->none
Std_Macro_4-->none
Std_Macro_5-->none
Std_MainFullscreen-->Alt+F11
Std_MeasureDistance-->None
Std_MergeProjects-->None
Std_New-->Ctrl+N
Std_OnlineHelp-->F1
Std_OnlineHelpWebsite-->None
Std_Open-->Ctrl+O
Std_OrthographicCamera-->V, O
Std_Part-->None
Std_Paste-->Ctrl+V
Std_PerspectiveCamera-->V, P
Std_Placement-->None
Std_Print-->Ctrl+P
Std_PrintPdf-->None
Std_PrintPreview-->None
Std_ProjectInfo-->None
Std_ProjectUtil-->None
Std_PythonHelp-->None
Std_PythonWebsite-->None
Std_Quit-->Alt+F4
Std_RandomColor-->None
Std_RecentFiles-->None
Std_Recompute-->Ctrl+R
Std_Redo-->Ctrl+Shift+Z
Std_Refresh-->Ctrl+R
Std_Revert-->None
Std_Save-->Ctrl+S
Std_SaveAll-->None
Std_SaveAs-->Ctrl+Shift+S
Std_SaveCopy-->None
Std_SceneInspector-->None
Std_SelBack-->S, B
Std_SelBoundingBox-->None
Std_SelForward-->S, F
Std_SelectAll-->None
Std_SelectVisibleObjects-->None
Std_SendToPythonConsole-->Ctrl+Shift+P
Std_SetAppearance-->Ctrl+D
Std_ShowObjects-->None
Std_ShowSelection-->None
Std_Test1-->Ctrl+T
Std_Test2-->None
Std_Test3-->None
Std_Test4-->None
Std_Test5-->None
Std_Test6-->None
Std_TestCmdFuncs-->None
Std_TestConsoleOutput-->None
Std_TestProgress1-->None
Std_TestProgress2-->None
Std_TestProgress3-->None
Std_TestProgress4-->None
Std_TestProgress5-->None
Std_TestQM-->None
Std_TestReloadQM-->None
Std_TextDocument-->None
Std_TextureMapping-->None
Std_TileWindows-->None
Std_ToggleBreakpoint-->F9
Std_ToggleClipPlane-->None
Std_ToggleNavigation-->Esc
Std_ToggleObjects-->None
Std_ToggleSelectability-->None
Std_ToggleVisibility-->Space
Std_ToolBarMenu-->None
Std_Transform-->None
Std_TransformManip-->None
Std_TreeCollapse-->None
Std_TreeCollapseDocument-->None
Std_TreeDrag-->T,D
Std_TreeExpand-->None
Std_TreeMultiDocument-->None
Std_TreePreSelection-->T,4
Std_TreeRecordSelection-->T,5
Std_TreeSelectAllInstances-->None
Std_TreeSelection-->T,G
Std_TreeSingleDocument-->None
Std_TreeSyncPlacement-->T,3
Std_TreeSyncSelection-->T,2
Std_TreeSyncView-->T,1
Std_TreeViewActions-->None
Std_Undo-->Ctrl+Z
Std_UnitsCalculator-->None
Std_UserInterface-->None
Std_ViewBottom-->5
Std_ViewBoxZoom-->Ctrl+B
Std_ViewCreate-->None
Std_ViewDimetric-->None
Std_ViewDock-->V, D
Std_ViewDockUndockFullscreen-->None
Std_ViewExample1-->None
Std_ViewExample2-->None
Std_ViewExample3-->None
Std_ViewFitAll-->V, F
Std_ViewFitSelection-->V, S
Std_ViewFront-->1
Std_ViewFullscreen-->F11
Std_ViewIsometric-->0
Std_ViewIvIssueCamPos-->None
Std_ViewIvStereoInterleavedColumns-->None
Std_ViewIvStereoInterleavedRows-->None
Std_ViewIvStereoOff-->None
Std_ViewIvStereoQuadBuff-->None
Std_ViewIvStereoRedGreen-->None
Std_ViewLeft-->6
Std_ViewRear-->4
Std_ViewRight-->3
Std_ViewRotateLeft-->Shift+Left
Std_ViewRotateRight-->Shift+Right
Std_ViewScreenShot-->None
Std_ViewStatusBar-->None
Std_ViewTop-->2
Std_ViewTrimetric-->None
Std_ViewUndock-->V, U
Std_ViewVR-->None
Std_ViewZoomIn-->Ctrl++
Std_ViewZoomOut-->Ctrl+-
Std_WhatsThis-->Shift+F1
Std_Windows-->None
Std_WindowsMenu-->None
Std_Workbench-->None
Surface_CurveOnMesh-->None
Surface_ExtendFace-->None
Surface_Filling-->None
Surface_GeomFillSurface-->None
TechDraw_2LineCenterLine-->None
TechDraw_2PointCenterLine-->None
TechDraw_3PtAngleDimension-->None
TechDraw_ActiveView-->None
TechDraw_AngleDimension-->None
TechDraw_Annotation-->None
TechDraw_ArchView-->None
TechDraw_Balloon-->None
TechDraw_CenterLineGroup-->None
TechDraw_ClipGroup-->None
TechDraw_ClipGroupAdd-->None
TechDraw_ClipGroupRemove-->None
TechDraw_CosmeticEraser-->None
TechDraw_CosmeticVertex-->None
TechDraw_CosmeticVertexGroup-->None
TechDraw_DecorateLine-->None
TechDraw_DetailView-->None
TechDraw_DiameterDimension-->None
TechDraw_Dimension-->None
TechDraw_DraftView-->None
TechDraw_ExportPageDXF-->None
TechDraw_ExportPageSVG-->None
TechDraw_ExtentGroup-->None
TechDraw_FaceCenterLine-->None
TechDraw_GeometricHatch-->None
TechDraw_Hatch-->None
TechDraw_HorizontalDimension-->None
TechDraw_HorizontalExtentDimension-->None
TechDraw_Image-->None
TechDraw_LandmarkDimension-->None
TechDraw_LeaderLine-->None
TechDraw_LengthDimension-->None
TechDraw_LinkDimension-->None
TechDraw_Midpoints-->None
TechDraw_PageDefault-->None
TechDraw_PageTemplate-->None
TechDraw_ProjectionGroup-->None
TechDraw_Quadrants-->None
TechDraw_RadiusDimension-->None
TechDraw_RedrawPage-->None
TechDraw_RichTextAnnotation-->None
TechDraw_SectionView-->None
TechDraw_ShowAll-->None
TechDraw_SpreadsheetView-->None
TechDraw_Symbol-->None
TechDraw_ToggleFrame-->None
TechDraw_VerticalDimension-->None
TechDraw_VerticalExtentDimension-->None
TechDraw_View-->None
TechDraw_WeldSymbol-->None
ViewIsometricCmd-->None
ViewOrthographicCmd-->None
ViewPerspectiveCmd-->None
ViewZoomToFit-->None
View_Measure_Clear_All-->None
View_Measure_Toggle_All-->None
refineFeatureTool-->None
