BOLTS Open Library of Technical Specifications
bernd
Re: BOLTS Open Library of Technical Specifications
Postby bernd » Sun Jul 02, 2017 6:44 pm
Jee-Bee
Postby Jee-Bee » Sun Jul 02, 2017 7:07 pm
Is it an idea that one (or more) from the FreeCAD forum have acces to BOLTS to maintain it without inter action of @JReinhardt ??
bernd
Postby bernd » Sun Jul 02, 2017 7:14 pm
Is it an idea that one (or more) from the FreeCAD forum have access to BOLTS to maintain it without inter action of @JReinhardt ??
read the issue. https://github.com/FreeCAD/FreeCAD-addons/issues/38 I have set up a gitrepo with a working BOLTS pachage for FreeCAD. I will try to get in touch with Johannes in this regard. He may will come up by one self because he will get informed about the posts on this topic. Just be patient.
Bernd
davecoventry
Postby davecoventry » Wed Jul 05, 2017 8:54 am
I have a Virtual Box VM running Windows XP and I've installed FreeCAD there.
The Bolts Library runs fine there.
I've recently upgraded to Debian 9, but the macro fails as described above.
~ Dave
bernd
Postby bernd » Fri Sep 22, 2017 10:12 am
bernd
Postby bernd » Fri Sep 22, 2017 7:50 pm
installing BOLTS by the use of FreeCAD installer should work again. If encounter any problems by the use of BOLTS from addon manager please post them here.
for reference:
https://github.com/FreeCAD/FreeCAD-addons/commit/cca3df
just tested the BOLTS from AddOn manager on my debin jessy with
OS: Debian GNU/Linux 8.9 (jessie)
Version: 0.17.12148 (Git)
Build type: Debug
Hash: be18a46df9927a81fcbca7e19b2b28497d2779b8
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
Locale: German/Switzerland (de_CH)
Installes fine and runs without any problems so far
bernd
cremofix
Postby cremofix » Wed Sep 27, 2017 10:10 am
Hello
I am quite new to freecad and very new to the bolts-library.
Now I installed bolts on my freecad 0.16 on an ubuntu system.
I can access the library and add parts. everything fine.
when i select a bearing 6005-ZZ it should have d=25,D=47 and B=12
the added bearing in freecad only is 6mm thick instead of 12mm
In the bearings-table on bolts-library.org the 6005-ZZ has the thickness correcly with 12mm
same problem with other bearings e.g. 608-ZZ (only 3.5 mm instead of 7mm)
always the freecad-thickness only seems to be half of the original
any idea?
thanks
cremofix
bernd
Postby bernd » Sat Oct 07, 2017 8:55 pm
For me it is 12 mm, but I may added the wrong one. Could you exact say which bearing did you add ...
bernd
thschrader
Postby thschrader » Sun Oct 08, 2017 9:51 pm
EDIT: ups, just before I was in the german forum... :oops:
Error when loading rectangular hollow profile from BOLTSFC
in FC0.16. I-Profile works. Loding rectangualr hollow
in FC0.17 is ok.
@Bernd:
Error beim Laden von Q-Rohr in FC0.16, I-Träger funktioniert.
Q-Rohr laden funktioniert aber in FC0.17.
Thomas
bernd
Postby bernd » Tue Oct 10, 2017 4:33 am
the Part::FaceMakerBullseye seams not supported by FreeCAD 0.16 https://github.com/berndhahnebach/BOLTS ... 5f7b85f888 I will have a look ...
