BOLTS Open Library of Technical Specifications
bernd
Re: BOLTS Open Library of Technical Specifications
Postby bernd » Tue Oct 10, 2017 7:46 am
For me https://www.bolts-library.org/ is no longer available. Could someone confirm this ?
thschrader
Postby thschrader » Tue Oct 10, 2017 9:53 am
Yes. German text means: connection not secure, blocked.
thomas
yorik
Site Admin
Postby yorik » Wed Oct 11, 2017 1:27 am
His certificate expired probably...
Postby Kunda1 » Wed Oct 11, 2017 2:39 am
confirmed. it's down
Montoya88
Postby Montoya88 » Thu Dec 21, 2017 4:45 am
bernd wrote:
Tue Oct 10, 2017 4:33 am
the Part::FaceMakerBullseye seams not supported by FreeCAD 0.16
Hi Bernd,
I'm also getting the same error message in V 0.16, this started to happen after I've Downloaded BOLTS to be used in V 0.17.
I Realized both versions are using the BOLTS file under the Users\AppData\Roaming\FreeCAD folder.
So the questions I have is:
1) Will BOLTS be fully functional for V 0.16?
2) Is it possible to have two folders for each version in the Users\AppData\Roaming\FreeCAD folder? Because when I get a add-on for one version it shows on the other.
ex:
Users\Tim\AppData\Roaming\FreeCADv0.16
Users\Tim\AppData\Roaming\FreeCADv0.17
Postby chrisb » Thu Dec 21, 2017 10:06 am
You can start FreeCAD with parameters for the directories:
Generic options:
  -v [ --version ]          Prints version string
  -h [ --help ]             Prints help message
  -c [ --console ]          Starts in console mode
  --response-file arg       Can be specified with '@name', too
  --dump-config             Dumps configuration
  --get-config arg          Prints the value of the requested configuration key
Configuration:
  -l [ --write-log ]        Writes a log file to:
                            /Users/cb/Library/Preferences/FreeCAD/FreeCAD.log
  --log-file arg            Unlike --write-log this allows logging to an
                            arbitrary file
  -u [ --user-cfg ] arg     User config file to load/save user settings
  -s [ --system-cfg ] arg   System config file to load/save system settings
  -t [ --run-test ] arg     Test case - or 0 for all
  -M [ --module-path ] arg  Additional module paths
  -P [ --python-path ] arg  Additional python paths
  --single-instance         Allow to run a single instance of the application
Montoya88
Postby Montoya88 » Fri Dec 22, 2017 7:35 am
Is this to be used in the Python Console?
Postby chrisb » Fri Dec 22, 2017 8:17 am
No, you probably have an icon to start FreeCAD. There you can add parameters in the properties. As an alternative you can start a shell - "cmd.exe" is its name on windows - and start FreeCAD from there. Don't forget the complete path to the FreeCAD binary.
NormandC
Postby NormandC » Tue Jan 16, 2018 2:59 am
There was an issue posted about it and jreinhardt replied: https://github.com/jreinhardt/BOLTS/issues/176
On 17 Oct 2017 jreinhardt wrote:That is related to OpenShift shutting down version 2 of their service. I will try to migrate the Website to Openshift V3.
bernd
Postby bernd » Thu May 16, 2019 5:23 am
BOLTS repos on github moved to an organisation ... https://forum.freecadweb.org/viewtopic. ... 10#p308558
