BOLTS Open Library of Technical Specifications
bernd
Re: BOLTS Open Library of Technical Specifications
Postby bernd » Thu Jun 06, 2019 5:59 am
Postby Kunda1 » Thu Jun 06, 2019 4:55 pm
:tada::clap::clap::clap:
carlopav
Postby carlopav » Fri Jun 07, 2019 1:02 am
Great!!! Thousand thanks!
kisolre
Postby kisolre » Fri Jun 07, 2019 5:00 am
Great work :) Now waiting for Py3 compatibility :)
bernd
Postby bernd » Fri Jun 07, 2019 7:10 am
It has Python3 compatibility allready. Just use FreeCAD 0.18.2 or above.
kisolre
Postby kisolre » Fri Jun 07, 2019 7:43 am
Just before previous post I tried with latest 0.19 windows conda build and got some errors. Did not investigate then assuming python incompatibility. Will check again when I get home.
kisolre
Postby kisolre » Fri Jun 07, 2019 10:21 am
I just reinstalled BOLTSFC and it gives this
  File "C:/Users/Wivern/AppData/Roaming/FreeCAD/Macro/start_bolts.FCMacro", line 1, in <module>
    import BOLTS
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\BOLTSFC\BOLTS\__init__.py", line 40, in <module>
    from .gui import freecad_bolts as boltsgui
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\BOLTSFC\BOLTS\gui\freecad_bolts.py", line 29, in <module>
    Ui_BoltsWidget,QBoltsWidget = uic.loadUiType(join(bolts_path,'bolts_widget.ui'))
<class 'SyntaxError'>: Missing parentheses in call to 'exec' (<string>, line 15)
with
OS: Windows 8.1
Version: 0.19.16687 (Git)
Hash: ff1fb11af15a7c5f7f0ba3ef79588e128f397c2c
Python version: 3.6.6
Qt version: 5.6.2
It works Ok with
OS: Windows 8.1 (6.3)
Version: 0.19.16886 (Git)
Hash: ed47e962d2c821bf1792889f6d7bdf457dcf6c9e
Python version: 3.6.8
Qt version: 5.12.1
Both FreeCADs use the same configuration/mod folder. Any idea what could be the problem? Or should I make another thread in the Help forum?
Syres
Postby Syres » Fri Jun 07, 2019 10:41 am
See https://forum.freecadweb.org/viewtopic. ... 0&t=36186
kisolre
Postby kisolre » Fri Jun 07, 2019 11:02 am
So the windows conda build is just old. Thanks for the hint :)
Postby Kunda1 » Fri Jun 07, 2019 9:19 pm
