App.ActiveDocument.License
App.ActiveDocument.CreatedBy
>>> import BOLTS
File "/home/normand/Dessins/Macros_FreeCAD/BOLTS/__init__.py", line 20, in <module>
from bolttools import blt_parser
File "/home/normand/Dessins/Macros_FreeCAD/BOLTS/bolttools/blt_parser.py", line 19, in <module>
import yaml
ImportError: No module named yaml
I did that, thanks for the hint. This is the kind of stuff you miss.normandc wrote: Turns out I needed to install the python-yaml package. Might be a good idea to add this info to your documentation.
I like the recursive acronym: BOLTS is a Open Library of Technical Specifications. It has one problem though: an internet search for it will not give you the result you want. But PARTS has the same problem.triplus wrote:Have you consider renaming your project form BOLTS to PARTS?
patience ...jreinhardt wrote:... It has one problem though: an internet search for it will not give you the result you want. But PARTS has the same problem.
