I only use Conda very occasionally but you appear to have the channels in the wrong priority order for what you want to achieve so have a search for Conda channel priority change or something along those lines.
FreeCAD Conda Distribution
Re: FreeCAD Conda Distribution
looo wrote: ↑Fri Feb 25, 2022 2:38 pm can you show the output of:
conda config --show channels
channels:
- conda-forge
- defaults
Carlo D.
- Various other stuffs.
Two questions:
1) is conda "fcenv-dev" updated to the new 1.0 version ? This is the result of today try to update my installation, I'm doing something wrong?
Sorry for the nuisance but I think having used it for some time that at least in Linux conda install is way better than AppImage, a part from the disk space usage it has the advantage of having directly available source for inspection and testing (python code mods).
Thanks for the hard work on mataining also a "conda install"
Regards
Carlo D.
2) could be https://wiki.freecadweb.org/Conda extended with some instructions to periodically update "conda installation" ?conda update -n fcenv-dev freecad
Collecting package metadata (current_repodata.json): done
Solving environment: done
# All requested packages already installed.
Regards
Carlo D.
- adrianinsaval
I think the appimage is a byproduct of the conda release rather than the other way aroundonekk wrote: ↑Wed Jun 15, 2022 2:21 pm Sorry for the nuisance but I think having used it for some time that at least in Linux conda install is way better than AppImage, a part from the disk space usage it has the advantage of having directly available source for inspection and testing (python code mods).
I can't really help you much with conda since I don't use it but what version do you have installed? Perhaps it is indeed the latest, if it's anything near or above 29177 it's pretty new, note that the 0.20 release is not even fully done yet and AFAIK master still hasn't been updated to report 1.0 version so it's normal if you still get it as 0.20 despite being newer than the actual 0.20 release.
no problems it was only as information.
I can't check version now, but it is for sure the latest.
Probably tomorrow I will check version and post here.
Regards
Carlo D.
Regards
Carlo D.
sgrogan wrote:
No news about 0.21 dev in conda fcenv-dev distribution?looo wrote:
TIA and Regards
Carlo D.
Thanks but how to update?looo wrote: ↑Wed Jun 22, 2022 12:14 pm here it is:
https://github.com/looooo/freecad-feeds ... c4d1446359
I issue:
conda info
active environment : None
shell level : 0
user config file : /home/carlo-arch/.condarc
populated config files : /home/carlo-arch/.condarc
conda version : 4.13.0
conda-build version : not installed
python version : 3.9.7.final.0
virtual packages : __linux=5.18.5=0
__glibc=2.35=0
__unix=0=0
__archspec=1=x86_64
base environment : /home/carlo-arch/miniconda3 (writable)
conda av data dir : /home/carlo-arch/miniconda3/etc/conda
conda av metadata url : None
channel URLs : https://conda.anaconda.org/freecad/label/dev/linux-64
https://conda.anaconda.org/freecad/label/dev/noarch
https://conda.anaconda.org/conda-forge/linux-64
https://conda.anaconda.org/conda-forge/noarch
https://repo.anaconda.com/pkgs/main/linux-64
https://repo.anaconda.com/pkgs/main/noarch
https://repo.anaconda.com/pkgs/r/linux-64
https://repo.anaconda.com/pkgs/r/noarch
package cache : /home/carlo-arch/miniconda3/pkgs
/home/carlo-arch/.conda/pkgs
envs directories : /home/carlo-arch/miniconda3/envs
/home/carlo-arch/.conda/envs
platform : linux-64
user-agent : conda/4.13.0 requests/2.27.1 CPython/3.9.7 Linux/5.18.5-artix1-1 artix/ glibc/2.35
UID:GID : 1000:1000
netrc file : None
offline mode : False
my channels are:
channels:
- freecad/label/dev
- conda-forge
- defaults
Regards
Carlo D.
- adrianinsaval
patience young padawan, the commit was 1h ago, the build is likely not finished yet
see: https://dev.azure.com/sppedflyer/feedst ... ew=results
Sorry I haven't noted the time of the commit!
Will be 0.20 downloadable as stable? so:
conda create --name fcenv --channel conda-forge freecad
TIA and Regards
Carlo D.
