FreeCAD Docker CLI
amrit3701
FreeCAD Docker CLI
Post by amrit3701 »
Kunda1 wrote: Thu Apr 30, 2020 12:35 pm
amrit3701 wrote: Thu Apr 30, 2020 9:37 am I suggest you to use https://hub.docker.com/r/amrit3701/freecad-cli docker image for your web application. In this image, I compiled FreeCAD without GUI and it gives better performance.
@amrit3701 Nice!
Perhaps we can add this to Compile_on_Docker or some variant page?
Yes, we can. Could you please add (FreeCAD Docker CLI) it then I will maintain that page? I am not too good in documentation :oops:
Amritpal Singh
Github, Like my work, sponsor me!
Re: FreeCAD Docker CLI
Post by Kunda1 »
@vocx how would you suggest we document this? Should I split up Compile on Docker to show these 2 alternate docker images or should I make a dedicated page for each one or another alternative ?
vocx
Post by vocx »
Kunda1 wrote: Thu Apr 30, 2020 9:07 pm @vocx how would you suggest we document this? Should I split up Compile on Docker to show these 2 alternate docker images or should I make a dedicated page for each one or another alternative ?
Separate page sounds fine.
Post by Kunda1 »
Heads up: I've also created a ticket at https://github.com/FreeCAD/Docker/issues/2 to address FC having multiple docker images.
vocx wrote: Fri May 01, 2020 1:04 am Separate page sounds fine.
What about collapsing divs of each docker image ? I ask because the page has already been translated to German.
Pros: Everything on one page, easy to find. Translations don't need to be moved.
Cons: Not able to link to specific section headers in collapsed divs.
vocx
Post by vocx »
Kunda1 wrote: Fri May 01, 2020 11:37 am What about collapsing divs of each docker image ? ...
Then don't collapse it. Just add the new information.
amrit3701
Post by amrit3701 »
Kunda1 wrote: Fri May 01, 2020 11:37 am Heads up: I've also created a ticket at https://github.com/FreeCAD/Docker/issues/2 to address FC having multiple docker images.
Thanks @Kunda1 for taking up the charge. Once you finished, please drop the page link here, then I will add more information. :)
Amritpal Singh
amrit3701
Post by amrit3701 »
Kunda1 wrote:
Hi @Kunda1,
I have documented FreeCAD docker (CLI mode). Here is the link: https://wiki.freecadweb.org/FreeCAD_Docker_CLI_mode.
Just confused where should I add this page: maybe at https://wiki.freecadweb.org/Compiling ?
Thanks,
Amritpal Singh
