[Solved] disable mouse wheel event on ComboBox
fc_tofu
Post by fc_tofu »
I have seen some thread complaining about mouse wheel event on ComboBox control.
https://forum.freecadweb.org/viewtopic.php?f=3&t=45144
Till recent FreeCAD build (0.19.21049/win64 Conda) , this issue has not been solved. I'm not coder, and cannot fully understand the difficulty of this issue, but found this issue has got solved elsewhere on the net.
https://bugreports.qt.io/browse/QTBUG-48620
https://stackoverflow.com/questions/330 ... 7#46742557
https://doc.qt.io/qt-5/qml-qtquick-cont ... abled-prop
https://stackoverflow.com/questions/324 ... -qcombobox
openBrain
Re: Qt Quick Controls 2 ComboBox disable mouse wheel event
Post by openBrain »
FreeCAD doesn't use Qt Quick.
Founder
Post by wmayer »
from PySide2 import QtCore
from PySide2 import QtWidgets
class WheelEventFilter(QtCore.QObject):
    def eventFilter(self, obj, ev):
        if obj.inherits("QComboBox") and ev.type() == QtCore.QEvent.Wheel:
            return True
        return False
app = QtWidgets.QApplication.instance()
filter = WheelEventFilter()
app.installEventFilter(filter)
fc_tofu
Post by fc_tofu »
openBrain wrote: Sat May 16, 2020 8:00 am FreeCAD doesn't use Qt Quick.
Thanks for correcting my naive mistake.
fc_tofu
Post by fc_tofu »
wmayer wrote: Sat May 16, 2020 8:16 am
Thank you.
Is there a plan to merge this fix to main branch of FreeCAD?
Founder
Re: [Solved] Qt Quick Controls 2 ComboBox disable mouse wheel event
Post by wmayer »
git commit c90db641881
In order to activate the filter you must create the boolean key ComboBoxWheelEventFilter in the group General and set it to true.
fc_tofu
Post by fc_tofu »
wmayer wrote: Fri May 22, 2020 8:46 am git commit c90db641881
Good news!
fc_tofu
Post by fc_tofu »
Thank you @wmayer, I just tested the latest build.
It seems your fix has already worked in ComboBox and ListBox(?).
With ListBox (I donnot know its exact name), I mean below.
Above all, manual added parameter “ComboBoxWheelEventFilter” is a must.
Congratulations!
OS: Windows 10 (10.0)
Version: 0.19.21280 (Git)
Hash: 6f3160db3e88733536c7eaf97ad7d6ebd21baccd
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Chinese/China (zh_CN)
openBrain
Post by openBrain »
Newly introduced parameter is now documented in Fine-tuning
@wmayer : could you please extend the event filter to also return false on QAbstractSpinBox class ? Spin boxes suffer the same issue as combo boxes. Thx.
fc_tofu
Post by fc_tofu »
openBrain wrote: Tue Jun 02, 2020 8:18 pm @wmayer : could you please extend the event filter to also return false on QAbstractSpinBox class ? Spin boxes suffer the same issue as combo boxes. Thx.
With SpinBox, you mean below?
