[Solved] disable mouse wheel event on ComboBox
openBrain
Re: [Solved] Qt Quick Controls 2 ComboBox disable mouse wheel event
Postby openBrain » Wed Jun 03, 2020 7:39 am
fc_tofu wrote:
Wed Jun 03, 2020 7:29 am
With SpinBox, you mean below?
Exactly. Your screenshot makes me think that probably the QListView is also concerned...
Site Admin
Postby wmayer » Wed Jun 03, 2020 8:46 am
openBrain wrote:
Tue Jun 02, 2020 8:18 pm
wmayer wrote:
Fri May 22, 2020 8:46 am
git commit c90db641881
In order to activate the filter you must create the boolean key ComboBoxWheelEventFilter in the group General and set it to true.
Newly introduced parameter is now documented in Fine-tuning
@wmayer : could you please extend the event filter to also return false on QAbstractSpinBox class ? Spin boxes suffer the same issue as combo boxes. Thx.
I don't know what you are after but filtering wheel events for spin boxes might not be what you actually want. If you click on a spin box and scroll it won't change the values any more -- don't know why this behaviour should be desired.
What I can imagine what you want is that if the mouse cursor is over a spin box that hasn't the focus it steals the focus when scrolling. To avoid this filtering wheel events doesn't work.
See: https://stackoverflow.com/questions/582 ... focus-when
openBrain
Postby openBrain » Wed Jun 03, 2020 11:28 am
Yep that's it. The idea is to prevent spin boxes to automatically steal focus on wheel events, so that it's possible to seamlessly scroll scrollable areas.
But you're right that it's not so simple as just catching the event at App level.
Thx for comprehensive reply (as usual). ;)
Site Admin
Re: [reOpen] disable mouse wheel event on ComboBox
Postby wmayer » Wed Jun 03, 2020 12:14 pm
Most of the suggestions in the SO thread offer a way by sub-classing. IMO this is not a good alternative as it cannot be guaranteed that nowhere a QSpinBox or QDoubleSpinBox is used -- hence no consistent behaviour possible.
One of the solutions offer a way without sub-classing but it still requires to explicitly set the focus policy in client code which is cumbersome too.
Here is my solution that works without sub-classing and without touching client code. It sets the focus policy of a spin box as soon as it becomes visible and only accepts wheel events if the spin box has the focus.
git commit fcddee292
openBrain
Postby openBrain » Wed Jun 03, 2020 1:22 pm
I totally agree with your remarks. Neither impose sub-classing nor having to hardcode focus policy is an acceptable solution.
Regarding your commit :
  • I like it, looks clever
  • I hate you. :twisted: This is kind of coding challenge I'd have liked to look at. But you're to easy at dealing with it. :lol:
  • Just a remark. In the specific case of Wheel type event, Qt strongly recommends to explicitly accept() or ignore() the event (especially ignore() is important to ensure the event is pushed to parent).
Site Admin
Postby wmayer » Wed Jun 03, 2020 2:01 pm
In eventFilter() you usually don't have to explicitly use accept() or ignore() because with the return value of true/false you define if an event should be filtered or not.
According to the Qt doc only for QEvent::ShortcutOverride an explicit call of accept() is required. And this makes sense because ShortcutOverride is a special event that is sent when a key is pressed and a receiver can claim to handle it. The QApplication will realize it and send a key event directly to the receiver. This is a nice way to achieve some sophisticated shortcut handling.
The accept() and ignore() methods most of the time are used in the event handlers like closeEvent(), showEvent(), hideEvent(), ...
openBrain
Postby openBrain » Wed Jun 03, 2020 2:27 pm
According the Qt doc, I think I'm right on this one. :D
Anyway, I saw some cases where it was omitted and it seems to work correctly though. ;)
Site Admin
Postby wmayer » Wed Jun 03, 2020 3:33 pm
You may do this in the event handler wheelEvent() but not necessarily in the eventFilter()
openBrain
Postby openBrain » Wed Jun 03, 2020 3:46 pm
You may, but this isn't what doc advises (it's a "should", not a "shall"). Anyway, this was just a remark, you can take or not. ;)
fc_tofu
Postby fc_tofu » Thu Jun 04, 2020 3:03 am
Many people who suffered from mouse wheel will benefit from @wmayer fix.
And IMO, “ComboBoxWheelEventFilter"=Ture could be made default vaule in future build.
Also hope some discussions.
