the "tesselate shape" function doesn't work on the latest 0.19pre builds for macOS anymore. An error message is attached, but I don't have any idea what to do with it. After I click on ok it says: Name 'MeshPart' is not defined.
I hope this will be fixed.. if there's anything I can to to help/test, I'd be happy to.
OS: macOS 10.15
Version: 0.19.21093 (Git)
Hash: 31bb4d84b92bc587bd79912dd15e132713610773
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
meshing seems broken on 0.19 macOS builds
- Screenshot 2020-05-17 at 13.12.32.png (39.83 KiB) Viewed 958 times
Re: meshing seems broken on 0.19 macOS builds
You should open the Report View under the View > Panels to see the full and non-truncated error message.
But from the snippet I could see obviously the linker fails to load a 3rd party library called libmesh.so which I think must be part of netgen.
Here's the "full report":
<class 'ImportError'>: dlopen(/Applications/FreeCAD.app/Contents/Resources/lib/MeshPart.so, 2): Symbol not found: __ZN6netgen7testoutE
Referenced from: /Applications/FreeCAD.app/Contents/Resources/lib/libNETGENPlugin.8.3.dylib
Expected in: /Applications/FreeCAD.app/Contents/Resources/lib/libmesh.so
in /Applications/FreeCAD.app/Contents/Resources/lib/libNETGENPlugin.8.3.dylib
File "<string>", line 5, in <module>
<class 'NameError'>: name 'MeshPart' is not defined
I think this related to this. https://forum.freecadweb.org/viewtopic. ... 08#p399217
The OSX build uses the same updated dependencies.
"fight the good fight"
I tried to avoid this, but actually there are versions of smesh available which are not strictly pinned against netgen. So the dependency solver simple combines an older package of smesh with the latest netgen. By pinning the smesh version to FreeCAD, and by using the updated smesh it should be possible to avoid such incompatibilities for future update cycles.
To solve this for now, we need to get the updated smesh working on win. Linux is already working and I hope osx will work without additional trouble.
