Part Design, Crash in recent 0.19 (2020-05-25)
I discovered a crash.
- Open the attached file .
- Load the Part Design Workbench
- Select Fillet002 in the tree
- Press the Delete key --> Crash!
Note that there is no crash when you delete Fillet002 with the "Edit/Delete" menu.
Gaël
OS: Ubuntu 18.04.4 LTS (i3/i3)
Version: 0.19.
Branch: unknown
Hash: 40600a55c2fe71ff589be677f6e427ccc937d003
Python version: 3.6.9
Qt version: 5.9.5
Locale: C/Default (C)
Gaël
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
Re: Part Design, Crash in recent 0.19 (2020-05-25)
Are you sure you uploaded the correct file, see screenshot?
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.21231 (Git)
Build type: Unknown
Hash: c1ca01b0e79efa44f39ee377bb97517e2fd7debf
Qt version: 5.9.5
I chose one of my most complex (30Mb) PD models (don't use PD much) and deleted the last Fillet with the Delete key absolutely fine.
Build type: Unknown
Qt version: 5.9.5
Yes, this is the correct file. What I wanted to do is actually modify something earlier in the tree. For this purpose, I changed the tip. I didn't want to delete the fillets because I wanted to record the radius values. Then I realized that the fillets don't make sense anymore so wanted to delete them.
Do you also get the crash with my file?
You talk about deleting Fillet002, but there is no such Fillet in the file.
I tried both fillets (i.e. Fillet and Fillet001) in arbitrary sequence - no crash, so it may be system dependent.
OS: macOS High Sierra (10.13)
Version: 0.19.21125 (Git)
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Deleting Fillet001 then Fillet with the Delete key I get this in the Report View (no hard crash) which maybe of use to the devs:
0 <App> Document.cpp(3715): Failed to recompute crash#Fillet001: Fillet not possible on selected shapes
Recompute failed! Please check report view.
29.3313 <App> Document.cpp(3715): Failed to recompute crash#Fillet: Fillet not possible on selected shapes
OS: Windows 7 SP 1 (6.1)
Python version: 3.6.8
Qt version: 5.12.1
Oh yes, I meant Fillet001.
The backtrace is
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7fa2f6dc8f20]
#1 0x7fa2f81c19b0 in QRasterPaintEngine::renderHintsChanged() from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5+0xf0
#2 0x7fa2f81da2a1 in QPainter::setRenderHints(QFlags<QPainter::RenderHint>, bool) from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5+0x51
#3 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x1ef506) [0x7fa2f87bf506]
#4 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x1f7fcd) [0x7fa2f87c7fcd]
#5 0x7fa2f8759f75 in QWidgetPrivate::paintBackground(QPainter*, QRegion const&, int) const from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x165
#6 0x7fa2f875cd1b in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0xb2b
#7 0x7fa2f875d3c0 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x360
#8 0x7fa2f875c366 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x176
#9 0x7fa2f875d3c0 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x360
#10 0x7fa2f875d549 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x4e9
#11 0x7fa2f875c366 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x176
#12 0x7fa2f875d3c0 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x360
#13 0x7fa2f875c366 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x176
#14 0x7fa2f875d3c0 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x360
#15 0x7fa2f875d549 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x4e9
#16 0x7fa2f875c366 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x176
#17 0x7fa2f875d3c0 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x360
#18 0x7fa2f875c366 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x176
#19 0x7fa2f875d3c0 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x360
#20 0x7fa2f875c366 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x176
#21 0x7fa2f875d3c0 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x360
#22 0x7fa2f875d549 in QWidgetPrivate::paintSiblingsRecursive(QPaintDevice*, QList<QObject*> const&, int, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x4e9
#23 0x7fa2f875c366 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x176
#24 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x163e64) [0x7fa2f8733e64]
#25 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x1640a5) [0x7fa2f87340a5]
#26 0x7fa2f874b67f in QWidgetPrivate::syncBackingStore() from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x4f
#27 0x7fa2f87631b8 in QWidget::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x368
#28 0x7fa2f8876c6b in QMainWindow::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x15b
#29 0x7fa2fa714a5b in Gui::MainWindow::event(QEvent*) from /usr/lib/freecad-daily-python3/lib/libFreeCADGui.so+0x7b
#30 0x7fa2f872483c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x9c
#31 0x7fa2f872c104 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x2a4
#32 0x7fa2fa377a88 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad-daily-python3/lib/libFreeCADGui.so+0x88
#33 0x7fa2f79a68d8 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x118
#34 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x164ec8) [0x7fa2f8734ec8]
#35 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x165ebf) [0x7fa2f8735ebf]
#36 0x7fa2f874d3c7 in QWidget::repaint(QRect const&) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x97
#37 0x7fa2f88cf6fe in QStatusBar::hideOrShow() from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x15e
#38 0x7fa2f88cf7aa in QStatusBar::showMessage(QString const&, int) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x6a
#39 0x7fa2fa70dea0 in Gui::MainWindow::showStatus(int, QString const&) from /usr/lib/freecad-daily-python3/lib/libFreeCADGui.so+0x190
#40 0x7fa2fa711100 in Gui::MainWindow::customEvent(QEvent*) from /usr/lib/freecad-daily-python3/lib/libFreeCADGui.so+0x220
#41 0x7fa2f79d607b in QObject::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x9b
#42 0x7fa2f876375b in QWidget::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x90b
#43 0x7fa2f8876c6b in QMainWindow::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x15b
#44 0x7fa2fa714a5b in Gui::MainWindow::event(QEvent*) from /usr/lib/freecad-daily-python3/lib/libFreeCADGui.so+0x7b
#45 0x7fa2f872483c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x9c
#46 0x7fa2f872c104 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x2a4
#47 0x7fa2fa377a88 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad-daily-python3/lib/libFreeCADGui.so+0x88
#48 0x7fa2f79a68d8 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x118
#49 0x7fa2f79a904d in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x1ed
#50 /usr/lib/x86_64-linux-gnu/libQt5Core.so.5(+0x2e4263) [0x7fa2f7a00263]
#51 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2e7) [0x7fa2f20c2417]
#52 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4c650) [0x7fa2f20c2650]
#53 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7fa2f20c26dc]
#54 0x7fa2f79ff88f in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x5f
#55 0x7fa2f79a490a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x13a
#56 0x7fa2f79ad9b4 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x94
#57 0x7fa2fa2e7a81 in Gui::Application::runApplication() from /usr/lib/freecad-daily-python3/lib/libFreeCADGui.so+0x14d1
#58 freecad-daily(+0x3522) [0x5606bbca1522]
#59 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fa2f6dabb97]
#60 freecad-daily(+0x421a) [0x5606bbca221a]
Doesn't crash with this version :
OS: Debian GNU/Linux 10 (buster) (GNOME/gnome)
Python version: 3.7.3
Qt version: 5.11.3
OCC version: 7.4.1.dev
Locale: French/France (fr_FR)
Qt version: 5.11.3
tellement nul les evolution du part design qui oblige à créer des body inutiles que je retourne travailler avec la version 0.16 bien plus facile et logique!!
Pourquoi cette regression??????
Par exemple, créer un cube sous part puis chamfreiner sous aprt desing en 0.16 était très facile. Sou 0.19 il faut creer en plus une body pour pourvoir faire ce chamfrein. Pourquoi compliquer??? quelle logique?
Dommage.
Dommage.
- Shalmeneser
* Evolution is for a better / logic organisation.jpgergaud wrote: ↑Mon Jul 04, 2022 5:52 am tellement nul les evolution du part design qui oblige à créer des body inutiles que je retourne travailler avec la version 0.16 bien plus facile et logique!!
Dommage.
* 0.20 is far better than 0.16.
* using different workbenches is not useful when you can stay in the same wb : don't use Part Chamfer when you can use PartDesign Chamfer !
