vanuan wrote: ↑Wed Sep 16, 2020 7:42 pm
So you're talking only about surfaces extruded linearly, not the free-form surfaces?
All types of surfaces for tangency must of course be supported.
What I typed above was just an extreamly simple example.
Priority one is to have at least bezier surfaces working for tangency (C1 - continuity).
Priority two will be bezier + one parameter acceleration curvature (C2 - continuity).
Priority three will be bezier + multi parameter acceleration along the curvature (C3 - continuity).
Priority four will be nurbs + multi parameter acceleration along the curvature (C3 - continuity).
Here acceleration will be understood as the sideways force an imaginary particle feels when traveling along the
simplified case of a straight line then an arc. While the imaginary particle travels along the straight line it doesn't feel any sideways forces. Exactly when it transits to the start of the arc it will experience a sideway force of magnitude 100%.
So the transition from zero sideforce to 100% sideforce is what we ultimately want to rule (manually set acceleration).
The distance over which this will happen is of course determined by the newly formed surface, in other words, the surface between the ruling surfaces.
