New bug (I guess)
New bug (I guess)
Hello everyone,
I am new at this software and I'm trying to learn it and for that I was watching this tutorial:
https://www.youtube.com/watch?v=_HEvhcl ... 26cn9idJrj
Yet I cannot follow the instructions as it is instructed, let me elaborate how:
1)Open FreeCAD
2)Open new document
3)Select part design
4)Create a new sketch
5)Select XY plane
6)Draw a rectangle (My problem starts from here now on)
7)Constraint a symmetry between top two points according to the vertical axis
(Here it can be seen that my sketch is over-constrained)
(And there is some problem with the sketch updating it is not symmetrical) (Updating problem can be gone with twitching [or playing (English not the first language)] around with the sketch) 8)Constraint a symmetry between right two points around the horizontal axis
(Same updating problem here too)
(Another over-constrain) 9)Proceed to fixing a length to the top line
(Set it to 200mm) (This error tab appears) My FreeCAD version informations are:
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Thank you for your attention!
1)Open FreeCAD
2)Open new document
5)Select XY plane
Qt version: 5.6.2
Re: New bug (I guess)
Please attach your file.
Can you reproduce with FreeCAD 0.19?
Your first post, welcome.
That tutorial is about 5 years old now. The code has advanced considerably. The channel was created by a well respected member of this forum, Roland Frank, who was killed in a car accident nearly three years ago.
I tried the latest daily Ubuntu build and it produces the same over constrained error message here in the development version...
OS: Ubuntu 18.04.4 LTS (KDE/plasma)
Version: 0.19.
Branch: unknown
Hash: bc309838dc96c74261ac88cac7d9b70c9f9aa552
Python version: 3.6.9
Qt version: 5.9.5
The problem is that the symmetry forces the top line to be horizontal, but there is already a horizontal constraint automatically inserted by the rectangle tool.
I am not sure if this is intentional or not. Probably abdulla would know, if someone else doesn't know the answer I will contact him and ask.
Most of us would not have noticed this I suppose because you no longer need to apply two symmetry constraints, one to the x and another to the y axes, you just select one pair of diagonally opposed vertices and apply the symmetry constrain against the sketch origin (the dot where the X and Y axes cross).
Jim
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
Jim
This is correct and perfectly on purpose. Mathematically, a symmetry against a vertical line implies the 2 points are horizontally aligned. So this is redundant and solver is correct.jmaustpc wrote: ↑Sat Jul 04, 2020 1:59 pm The problem is that the symmetry forces the top line to be horizontal, but there is already a horizontal constraint automatically inserted by the rectangle tool.
this is an example file showing what he is talking about.
It seems to be a change in behaviour in the code over the last 5 years, I am not sure if it is intentional or not but I think it is. Logically I would have thought a line could be symmetrical to an axis without needing to be perpendicular to it, but symmetry constrain forced the line to be perpendicular, you are no doubt correct about it from a maths point of view, I think Abdulla told me that too once a while ago. Perhaps I am confusing maths terms for symmetrical and equidistant?
Jim
@openBrain
I don't use FreeCAD 0.19 (most correctly I can't because this version I use is the one I downloaded from the website and don't know where to download version 0.19 and even if I did, I don't know if it is stable).
I attached the file.
Metin
Metin
- The_Buggy_Rectangle.FCStd
- (5.47 KiB) Downloaded 29 times
We had this debate a couple of years ago, and I was overruled. Strictly speaking line symmetry implies a mirror placement, which further implies the line between the symmetry points needs to be perpendicular to the line of symmetry. However, it is often the case that one wants the points to be equidistant from the line, with no other constraints.jmaustpc wrote: ↑Sat Jul 04, 2020 2:09 pm It seems to be a change in behaviour in the code over the last 5 years, I am not sure if it is intentional or not but I think it is. Logically I would have thought a line could be symmetrical to an axis without needing to be perpendicular to it, but symmetry constrain forced the line to be perpendicular, you are no doubt correct about it from a maths point of view
That feature is not implemented through a simple operation in the sketcher.
The difference over five years is mainly that the sketcher is much more alert to redundant constraints. In this simple case the redundancy may not be very important for the solver, but it is flagged and disallowed.
Gene
If the compiler is going to give an error when I'm going to use symmetry function is there any other function I can use like equidistancy?openBrain wrote: ↑Sat Jul 04, 2020 2:05 pmThis is correct and perfectly on purpose. Mathematically, a symmetry against a vertical line implies the 2 points are horizontally aligned. So this is redundant and solver is correct.jmaustpc wrote: ↑Sat Jul 04, 2020 1:59 pm The problem is that the symmetry forces the top line to be horizontal, but there is already a horizontal constraint automatically inserted by the rectangle tool.
I can confirm it does the same in 0.19.openBrain wrote: ↑Sat Jul 04, 2020 2:05 pmThis is correct and perfectly on purpose. Mathematically, a symmetry against a vertical line implies the 2 points are horizontally aligned. So this is redundant and solver is correct.jmaustpc wrote: ↑Sat Jul 04, 2020 1:59 pm The problem is that the symmetry forces the top line to be horizontal, but there is already a horizontal constraint automatically inserted by the rectangle tool.
Also, I agree that mathematically this is correct.
But, this harkens to the the the post about trimming a circle. https://forum.freecadweb.org/viewtopic.php?f=3&t=48289
If auto constrains, avoid auto redundant, etc. are turned it doesn't correct the issue.
Even if they are turned off and you use the rectangle tool, it adds horizontal/vertical constraints. And adding a symmetry constraint then produces the redundancy.
So, the user should be instructed or just know the horizontal constraint needs to be removed first?
In the case of the circle trim, the constraints (point on line, endpoint coincident, tangent) were basically fitting each other and messing things up.
For some reason, I never noticed either issue until the last few days. In this OP though it is noted in 0.18 and I've been running 0.19 daily exclusively for a year.
OS: Ubuntu 19.10 (XFCE/ubuntustudio)
Version: 0.19.
Branch: unknown
Hash: 33841eb827045002a5fa3e82cde7ecccb9e67cdb
Python version: 3.7.5
Qt version: 5.12.4
Hmm...if you make, for example, a trapezoid/rhomboid with no vertical constraints and attempt to apply the symmetry to only the top or bottom the same occurs.jmaustpc wrote: ↑Sat Jul 04, 2020 1:59 pm ...
My point is that the diagonal constraint is a special, not general, case.
A very useful thing indeed, but, not applicable in every case.
(And, another choice of tool may be the square tool, since it does not add the horizontal/vertical constraints.)
