Hackaday.com posted an article about making bottle threads: Learn The Secrets Of Matching Bottle Cap Threads To One Another
The article notes that most bottle threads are standardized. It links to a calculator that has presets for the standards and also allows the user to enter measured threads if needed. Bottle cap thread calculator
I tried using some of the presets with ThreadProfile workbench (just set the pitch and diameter after adding a helix and V thread profile) and with good results (this one is 5 threads of 13-SP415):
Using ThreadProfile workbench for bottle threads
Re: Using ThreadProfile workbench for bottle threads
This one on thingiverse looks more like a buttress thread, but even that's not exactly right.
https://www.thingiverse.com/thing:701895
Umm...my point wasn't that my example created anything usable, but that the resource of standard for bottle thread values was useful.TheMarkster wrote: ↑Mon Jul 13, 2020 5:10 am This one on thingiverse looks more like a buttress thread, but even that's not exactly right.
After researching this a bit more I see there are 2 types of profiles, "L" and "M". The L profile is similar to a v thread, but 30 degrees and a rather blunt tip. The M profile is a buttress type profile 45 degrees on one and 10 degrees on the other. The ThreadProfile Buttress profiles use 45/7 degrees.
I updated the workbench to add some support for bottle threads, the m style 45/10 buttress threads. You might have to flip the threadprofile object around depending on how you want the buttress threads oriented. The only sample I have to test against is the one I found on thingiverse. That one seems to be bang on, but I don't know about the other preset sizes.
OS: Windows 8.1 (6.3)
Version: 0.19.21982 (Git)
Hash: 11419ecfafb4029e21fa9860b3d65bb5807bdf50
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.12.1
- tp.JPG (31.01 KiB) Viewed 1958 times
Thanks for the report. It looks like some changes to Draft workbench might be the issue. I'll update to the latest build and see if I can fix it.
Edit: I just pushed an update to version 1.63.
