Feature Request: 3D PDF Exporting to Asymptote format.
jruiz
Postby jruiz » Fri Jul 24, 2020 11:42 am
Hi.
Just wondering if it could be feasible (no to hard to do) to add to FreeCAD the feature of exporting projects to Asymptote (.asy) format.
After that, with LaTeX, it could be get an interactive .pdf file showing the project.
Regards.
The following was written after part of the discussion have been developed:
I have uploaded some FreeCAD video tutorials to www.youtube.com/yosoyvenezolano
jruiz
Re: Feature Request: 3D PDF Exporting to Asymptote format.
Postby jruiz » Sun Aug 23, 2020 12:00 am
For people not knowing Asymptote programming here there is a link to a video tutorial showing a way of getting an interactive pdf-3d file from Asymptote code into LaTeX code.
Getting interactive pdf-3d files from Asymptote and LaTeX
Regards.
Site Admin
Postby wmayer » Mon Aug 24, 2020 1:22 pm
There is a different way to create 3D PDF files. The MeshLab project already supports this for many years and from this workflow we have adopted the step to create IDTF meshes.
The workflow is:
  1. Create a IDTF mesh
  2. Convert the IDTF file into u3d format. You get the utility from here: https://github.com/ningfei/u3d
  3. LaTeX has a package to read in u3d files
Another way is to use the PRC format. There is a library libPRC (that uses libharu and parts of asymptote) that can be used to directly create 3D PDF files without using a LaTeX installation.
Here I have implemented a little utility that creates a 3D PDF from a BMS mesh file (it's the internal mesh format of FreeCAD).
https://github.com/wwmayer/Pdf3D
In order to build this application you must clone this repository and make sure to also checkout the sub-modules. Then build it with:
mkdir build
cd build
cmake ..
make
Then use it like this:
./mshtopdf input.bms -o output.pdf
This version doesn't support any materials but only raw mesh data. The libPRC library offers a tool to create a pdf from an OSG scene graph. So, maybe it might be an option for the future to implement a tool to create a pdf from an OpenInventor scene.
jruiz
Postby jruiz » Mon Aug 24, 2020 11:48 pm
The workflow is:
Thanks a lot.
Some weeks ago I uploaded a video tutorial explaining this workflow. :D
A way of getting interactive pdf-3d (1/2) (From FreeCAD, MeshLab and LaTeX)
mkdir build
cd build
cmake ..
make
Thank you very much again.
Gonna take a look at this method.
In this way can we manage color and lights/shadows of the models?
By the way. Do you know about any free (free as in freedom) viewer with which these pdf-3d can be opened for interacting with them?
Regards.
Site Admin
Postby wmayer » Tue Aug 25, 2020 9:05 am
Not with the bms format because it doesn't support materials, lights or colors. However, as said if we implement a converter to export a OpenInventor scene using libPRC it will be possible. Coin3d offers the class SoVectorizeAction and in a sub-class the virtual methods can be re-implemented exporting to the prc format.
Here is the code to convert an osg scene (OpenSceneGraph) to the prc format: https://github.com/XenonofArcticus/libP ... /osgdb_prc
No, the only application I know of that supports 3D PDF is the Acrobat Reader.
Btw, in the linked video above you talked about the Asymptote Vector graphic language. I had a quick look at it but couldn't figure out how one would export 3D data. Do you know how to do this or do you have a simple example?
If it's not too difficult it's still an option to export to the .asy format as this way we don't need a 3rd party library.
Site Admin
Postby wmayer » Tue Aug 25, 2020 10:09 am
A related thread which discusses a few more options can be found here: https://forum.freecadweb.org/viewtopic.php?f=24&t=20224
jruiz
Postby jruiz » Tue Aug 25, 2020 9:07 pm
I am not very sure of understanding you question.
In Asymptote: The Vector Graphics Language some details are explained.
Once an Asymptote code is compiled a pdf is generated.
Again, not sure about this question:
-in Asymptote page there are examples of codes.
Site Admin
Postby wmayer » Wed Aug 26, 2020 8:32 am
Yesterday I tried a pdf file which was created from a bms file and when opening it inside the Acrobat reader there are a lot of options to set lighting, shadows, wireframe, points, ... display modes and a few things more.
It's not a free (only freeware with the option to buy a license) and only runs on Windows but is an alternative to the Acrobat reader: PDF-XChange Editor / Editor Plus
On their website they claim they support 3D but I couldn't get it working to display the exported mesh.
There are many examples but I couldn't find one where a 3D mesh (with materials) will be created.
jaisejames
Postby jaisejames » Wed Aug 26, 2020 9:10 am
Site Admin
Postby wmayer » Wed Aug 26, 2020 11:06 am
Many thanks for the link.
I had to install a very old Blender version in order to get the script being accepted.
Here is the output of a mesh cube:
 * Asymptote export of Untitled, SCE:Scene
 * produced using asymptote_export.py 1.1
 * by Scott Pakin, scott.blend@pakin.org
import three;
size(500);
// CA:Camera, OB:Camera
currentprojection = perspective(camera = (7.4811, -6.5076, 5.3437),
                                target = (-58.005, 54.559, -39.181),
                                autoadjust = false,
                                showtarget = false,
                                up = (-0.31737, 0.31247, 0.89534));
// LA:Spot, OB:Lamp
// WO:World
currentlight = light(diffuse = rgb(1, 1, 1),
                     specular = rgb(1, 1, 1),
                     background = rgb(0.078281, 0.16041, 0.25),
                     0.56639, 0.21839, 0.79467);
// ME:Cube, OB:Cube
draw(surface((-1, -1, -1)--(-1, -1, 1)--(-1, 1, 1)--(-1, 1, -1)--cycle),
     rgb(0.8, 0.8, 0.8));
draw(surface((1, 1, 1)--(1, 1, -1)--(-1, 1, -1)--(-1, 1, 1)--cycle),
draw(surface((1, 1, -1)--(1, -1, -1)--(-1, -1, -1)--(-1, 1, -1)--cycle),
draw(surface((1, 1, 1)--(-1, 1, 1)--(-1, -1, 1)--(1, -1, 1)--cycle),
draw(surface((1, 1, -1)--(1, 1, 1)--(1, -1, 1)--(1, -1, -1)--cycle),
draw(surface((1, -1, -1)--(1, -1, 1)--(-1, -1, 1)--(-1, -1, -1)--cycle),
