What a good information!easyw-fc wrote: ↑Thu Sep 24, 2020 7:54 amI'm on LMint and it worked after installingI'm also on win10 and I tried with miktex ...Code: Select all
texlive-latex-extra
in miktex I can do:and it works...Code: Select all
pdflatex meshedPadInteractivo.tex asy meshedPadInteractivo-*.asy pdflatex meshedPadInteractivo.tex
this command (that works fine on linux) hangs instead on miktek (win):EDIT:Code: Select all
asy -f pdf meshedPad.asy
the command works fine even on win10 switching to texlive:ThxCode: Select all
Thank you very much!
