Geotechnical Work Addon
geoguy
Postby geoguy » Thu Aug 06, 2020 12:20 pm
I am new to this forum, Is there an existing addon for modeling excavation support systems (shoring) such as sheet piling, soldier piles, soil nails, etc. for geotechnical application? something like this:
https://blog.buildllc.com/2015/01/shoring-101/
https://www.advenser.com/site-underground-modeling/
Model Input:
1. External file from civil (topo) and from structural engineer (below ground portion of the building)
2. user input: soldier pile/sheet pile locations and geometry, some properties, tiebacks if needed.
Model output:
1. plan view
2. elevation views
3. Section views
4. Schedule of quantities from soldier piles and tieback geometry and properties
some examples of drawings
https://wsdot.wa.gov/publications/fullt ... 1_A2_1.pdf
https://wsdot.wa.gov/publications/fullt ... 1_A3_2.pdf
https://wsdot.wa.gov/publications/fullt ... 1_A3_3.pdf
paullee
Re: Geotechnical Work Addon
Postby paullee » Thu Aug 06, 2020 3:50 pm
Maybe you can cross-post in the Arch/BIM forum or FEM forum
vocx
Postby vocx » Fri Aug 07, 2020 6:54 am
...for geotechnical application? something like this:
This is the thread for the Geomatics Workbench (HakanSeven).
This is the thread for the Trails Workbench (Joel Graff).
The "Geomatics" workbench was merged into the Trails Workbench a few months ago, so you should not try to install it by itself now.
The Geomatics workbench was essentially a fork of the GeoData Workbench by microelly2. However, since GeoData was no longer developed by its author, at this point in time you should probably try Trails before anything else.
bernd
Postby bernd » Fri Aug 07, 2020 11:32 am
... at this point in time you should probably try Trails before anything else.
Just gave it a try on latest LP version ... I got the following error:
13:30:44  During initialization the error "No module named 'freecad.trails.project.support'" occurred in freecad.trails
13:30:44  --------------------------------------------------------------------------------
13:30:44  Traceback (most recent call last):
  File "<string>", line 150, in InitApplications
  File "importlib\__init__.py", line 126, in import_module
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 678, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "C:\Users\BHA\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\init_gui.py", line 29, in <module>
    from .corridor.template import ViewTemplateLibrary
  File "C:\Users\BHA\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\corridor\template\ViewTemplateLibrary.py", line 31, in <module>
    from . import TemplateLibrary, SketchTemplate
  File "C:\Users\BHA\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\corridor\template\TemplateLibrary.py", line 47, in <module>
    from ...project.support import document_properties
ModuleNotFoundError: No module named 'freecad.trails.project.support'
OS: Windows 10 (10.0)
Version: 0.19.22130 (Git)
Hash: dc65b055e5143a7d7349520da466d4d722df57e8
Python version: 3.6.8
Qt version: 5.12.1
Locale: German/Switzerland (de_CH)
thschrader
Postby thschrader » Fri Aug 07, 2020 12:11 pm
Bernd, try conda.
https://forum.freecadweb.org/viewtopic. ... 5&start=10
bernd
Postby bernd » Fri Aug 07, 2020 1:55 pm
What is the problem with LP version? It should work with LP as well! If not we should fix it. I would even help with it!
bernd
Postby bernd » Fri Aug 07, 2020 2:00 pm
we really should fix it because same happens on linux
16:01:34  During initialization the error "No module named 'pivy_trackers.pivy_trackers'" occurred in freecad.trails
16:01:34  --------------------------------------------------------------------------------
16:01:34  Traceback (most recent call last):
  File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "/home/hugo/.FreeCAD/Mod/trails/freecad/trails/__init__.py", line 53, in <module>
    'pivy_trackers.pivy_trackers.tracker.context_tracker', 'ContextTracker')
  File "/home/hugo/.FreeCAD/Mod/trails/freecad/trails/__init__.py", line 50, in import_class
    return getattr(import_module(path, name), name)
  File "/home/hugo/.FreeCAD/Mod/trails/freecad/trails/__init__.py", line 43, in import_module
    return __import__(path, globals(), locals(), _name_list)
ModuleNotFoundError: No module named 'pivy_trackers.pivy_trackers'
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.22208 (Git)
Build type: Unknown
Hash: e813c5adfdb48f4b4c27966cb8b04948e97573d2
Python version: 3.7.3
Qt version: 5.11.3
bernd
Postby bernd » Fri Aug 07, 2020 2:04 pm
what is this pivy_trackers.pivy_trackers ?
I seam to have pivy_trackers installed ...
>>> import pivy_trackers
>>> import pivy_trackers.pivy_trackers
>>> pivy_trackers.__dir__()
['__name__', '__doc__', '__package__', '__loader__', '__spec__', '__file__', '__path__']
bernd
Postby bernd » Fri Aug 07, 2020 2:15 pm
Ahh pivy_trackers is part of trails workbench but It will not installed because it is a different repository ...
https://github.com/joelgraff/freecad.trails
Ahh it needs to be installed with the AddOn manager too. I installed pivy_trackes with AddOn manager but still
['__name__', '__doc__', '__package__', '__loader__', '__spec__', '__path__', '__file__', '__cached__', '__builtins__']
thschrader
Postby thschrader » Fri Aug 07, 2020 2:17 pm
Bernd, please see post from hakan on
https://forum.freecadweb.org/viewtopic.php?f=3&t=47745
Bug should be fixed now...
