Geotechnical Work Addon
Joel_graff
Re: Geotechnical Work Addon
Postby Joel_graff » Fri Aug 07, 2020 2:20 pm
bernd wrote:
Fri Aug 07, 2020 2:15 pm
Ahh pivy_trackers is part of trails workbench but It will not installed because it is a different repository ...
https://github.com/joelgraff/freecad.trails
Ahh it needs to be installed with the AddOn manager too. I installed pivy_trackes with AddOn manager but still
The reason for that is a name collision. The pivy_trackers repo is incorporated into Trails as a submodule. As a result, the code is not cloned unless it's called with the --recursive switch when calling git clone. I did it because it really helped me during development, but now that geotechnical has been merged, it's creating headaches for everyone.
If the Addon Manager can add the --recursive switch that would be the easiest fix. Otherwise, I guess I can remove the submodule this week. The problem is, I have another submodule I use too...
thschrader
Postby thschrader » Fri Aug 07, 2020 2:26 pm
some more info on using trails-wb...
https://forum.freecadweb.org/viewtopic. ... 63#p410963
vocx
Postby vocx » Fri Aug 07, 2020 2:50 pm
Yes, Trails is a bit special because it requires various sub-packages that Joel is developing. So you need to have them all installed.
Postby bernd » Fri Aug 07, 2020 7:32 pm
@joel:
got the point
That should be doable, and would be the best IMHO too.
Postby bernd » Fri Aug 07, 2020 7:34 pm
next error ...
ModuleNotFoundError: No module named 'freecad_python_support.tuple_math'
where do I get this, and where do I have to install this.
Postby bernd » Fri Aug 07, 2020 7:35 pm
next error ...
https://github.com/joelgraff/freecad_python_support installed to /freecad_python_support
Joel_graff
Postby Joel_graff » Fri Aug 07, 2020 7:41 pm
Delete FreeCAD Trails from /Mod and install from the command line by calling:
git clone --recursive https://github.com/joelgraff/freecad.trails
This will make sure the code for both submodules is automatically installed.
Postby bernd » Fri Aug 07, 2020 7:46 pm
yeah, simple and works great but new errors ...
AttributeError: module 'pivy.coin' has no attribute 'SoGeoCoordinate'
Joel_graff
Postby Joel_graff » Fri Aug 07, 2020 7:52 pm
You may have an outdated version of coin. Support for SoGeoCoordinate (among others) was added in March:
https://github.com/coin3d/pivy/commit/3 ... 5f1969c556
Postby bernd » Fri Aug 07, 2020 7:52 pm
>>> from pivy import coin
>>> len(sorted(coin.__dir__()))
4984
>>> for e in sorted(coin.__dir__()):
...     print(e)
COIN_MAJOR_VERSION
COIN_MICRO_VERSION
COIN_MINOR_VERSION
COIN_NAVIGATION_EVENT_PREFIX
SoFullPath_fromSoPath
SoFullPath_swigregister
SoGLBigImage
SoGLBigImage_getClassTypeId
