Geotechnical Work Addon
bernd
Re: Geotechnical Work Addon
Postby bernd » Fri Aug 07, 2020 7:56 pm
Joel_graff wrote:
Fri Aug 07, 2020 7:52 pm
You may have an outdated version of coin. Support for SoGeoCoordinate (among others) was added in March:
https://github.com/coin3d/pivy/commit/3 ... 5f1969c556
:shock: Where do I get this from?
paullee
Postby paullee » Fri Aug 07, 2020 8:00 pm
Thanks fixing Trails, since Geodat and Geomatic are no longer maintained, had tried to use Trails but it is far from my capability to install it :D
Joel_graff
Postby Joel_graff » Fri Aug 07, 2020 8:11 pm
Errr.. The daily PPA? Maybe use the AppImage? I'm not entirely sure. Those would be the sources I'd try first, though.
Pivy is hard-linked against coin, so it may mean that you'd have to update your version of Coin as well. At this point, I'm going to guess the AppImage or a fresh install of FreeCAD-Daily is going to be your best shot. Kurt may know, though pivy is @loooo's baby, but I don't know if he's around anymore?
Otherwise, I relied on @NormandC to save my butt when it came to stuff like this... and he seems to be gone, too. :(
HakanSeven12
Postby HakanSeven12 » Fri Aug 07, 2020 8:26 pm
Lp version doesn't support SoGeo nodes. Use conda version.
bernd
Postby bernd » Fri Aug 07, 2020 8:28 pm
ATM I am on Debian Linux. Are there debs available?
Joel_graff
Postby Joel_graff » Fri Aug 07, 2020 9:39 pm
You can't run the conda AppImage on Debian?
bernd
Postby bernd » Sat Aug 08, 2020 6:37 am
I compile FC myself. Nevermind, I will wait ... The time beeing I use geodata wb.
Joel_graff
Postby Joel_graff » Sat Aug 08, 2020 1:29 pm
We could try to moderate the dependency on SoGeoCoordinate. It's not necessary unless you're using very large coordinates that exceed the limits of 32-bit, single-precision floating point. You aren't the only person with the issue, after all. SoGeoCoordinate is necessary for civil / transportation geotechnical datasets (which may span tens or hundreds of km in area), but it completely breaks compatibility with the current stable release.
I can take a look at it and see if maybe there's a way to use a sort of runtime directive to disable SoGeoCoordinate for earlier versions of FreeCAD later this week.
HakanSeven12
Postby HakanSeven12 » Sat Aug 08, 2020 4:55 pm
The main problem is lp version doesn't include latest chances that add sogeo classes to pivy. I think lp needs an update.
bernd
Postby bernd » Sun Aug 09, 2020 3:51 pm
it is not only lp on windows, mos linux coin pivy have the same problem.
@joel that would be great if we could just not use on systems whivh do not have it. Most people do not use tons of data if starting with trails.
If we would do this and the recoursive download of submodules with the addon manager trais would install just as simple as any other work bench.
