Geotechnical Work Addon
HakanSeven12
Re: Geotechnical Work Addon
Postby HakanSeven12 » Fri Aug 21, 2020 4:50 pm
bernd wrote:
Fri Aug 21, 2020 4:17 pm
is there a special reason why GeoDataWB with upper case chars and not such simple name as geoimport for all these kind of tools?
No. I will add gd to utm option to my point importer. So you can import all file formats that geodata support. Then I will remove that folder and only keep specific tools like osm or srtm.
vocx
Postby vocx » Fri Aug 21, 2020 6:44 pm
GeoDataWB was originally made by microelly2, so I guess Hakan and Joel just copied the directory as is. Most of the code here was written by microelly2, and wasn't entirely rewritten.
bernd
Postby bernd » Fri Aug 21, 2020 7:23 pm
it is not about the content of GeoDataWB. The content is fine. It is about the directory name. Why GeoDataWB? The name geoimport would fit much better since it would describe what modules are inside. Furthermore it would not have upper character. We still are in a early version where such rename is just possible since these tools from trails are not yet widly used. Once more people use it such change is much more difficault.
bernd
Postby bernd » Fri Aug 21, 2020 9:24 pm
runs smooth on Win Libpack version :)
OS: Windows 10 (10.0)
Version: 0.19.22209 (Git)
Hash: 9c3f9b72a82249d5fcf1f543dd69a78740251b26
Python version: 3.6.8
Qt version: 5.12.1
Locale: German/Switzerland (de_CH)
Joel_graff
Postby Joel_graff » Mon Aug 24, 2020 12:34 pm
I have had the same thoughts - there is a need for some cleanup on microelly's geodata code base, mostly in the form of naming conventions. filenames should be snake-case (lowercase and underscores), as well as some structural / path changes. But I haven't really decided on what might be a good approach.
The issue, really, is that Trails (as I've developed it) is largely separate from microelly and Hakan's work... and it needs to be better reflected in the file structure, I think.
bernd
Postby bernd » Tue Aug 25, 2020 6:35 pm
totally agree!!!
another one I would (for importOSM I already did) change, because the modules are huge. Split import code from gui widget import code.
bernd
Postby bernd » Fri Sep 18, 2020 1:22 pm
@Joel_graff:
would you accept a PR which renames GeoDataWB to geoimport?
freedman
Postby freedman » Sun Sep 20, 2020 5:49 am
Can you make a small piece of the OSM map and post it in a FCtd file, maybe something with elevation. If not is there a simple way I can view something like what what you show or is it all test stuff.
I want to try the elevation data on my SIM code
Thanks
Joel_graff
Postby Joel_graff » Mon Sep 21, 2020 4:54 pm
@Joel_graff:
sure. I have no issues with that, so long as it doesn't break anything. Hakan may want to review it before accepting since he's more familiar with the code base.
ping
HakanSeven12
Postby HakanSeven12 » Mon Sep 21, 2020 5:40 pm
I agree with you
