Now in FreeCAD available option 2D-Dwg/Dxf export option ( by using some external attachment "ODAFileConverter").
I have just query here, Can we give the optional option here If the user has any DWG compatible software on their system, so they can give the "DWG compatible software path" from FreeCAD in Import/Export>> DWG option, replace of "ODAFileConverter" If it possible. Then User can able to export all types of DWG/DXF objects in "DWG compatible software" without any interruption.
If the user clicks on the export option button in FreCAD >>"DWG compatible software" open with object data.
Can we give a solution to the DWG-3D object export options?
Re: Can we give a solution to the DWG-3D object export options?
Moved as it's a feature request to Open discussion forum.
Now if we export data in DWG it converts in PolyFaceMesh How to export data solid 3D ACIS entity.
Is there any other software that can produce a 3D DWG file from command-line input?
AutoCAD & ARES CAD, Can we do if will port data in AutoCAD&ARES CAD ( Like OLE object), then we can be saved data in DWG.
