Ticket #4451: cant open Openscad file *.scad
Postby Kunda1 » Thu Oct 15, 2020 5:54 pm
Discussion thread for issue #4451: cant open Openscad file *.scad
jmaustpc
Re: Ticket #4451: cant open Openscad file *.scad
Postby jmaustpc » Thu Oct 15, 2020 9:12 pm
From the ticket
if i try open some scad files with operation hull it will not successfully ended but traceback is
keithsloan52 wrote:ping
Hi Keith, I wonder if you would be interested in looking at this? No pressure, just thought you might. :)
JIm
sgrogan
Postby sgrogan » Thu Oct 15, 2020 9:48 pm
Anyone have a test .scad file where this fails.
The current https://github.com/FreeCAD/FreeCAD/blam ... es.py#L502 import looks like a new style "namespace" import but the OpenSCAD WB hasn't been ported to this style.
The reporter's fix appears valid, but I don't have a .scad file using "hull" to test.
"fight the good fight"
jmaustpc
Postby jmaustpc » Fri Oct 16, 2020 3:16 am
Is this one suitable? It was attached to the ticket, I think you would have noticed so I suspect isn't suitable? :)
I downloaded it and then attached it to this post.
hull.scad
(68 Bytes) Downloaded 9 times
Jim
keithsloan52
Postby keithsloan52 » Fri Oct 16, 2020 8:09 am
I have a new style namespace version of the OpenSCAD WB in my GitHub repro ( Now made private) and it appears OpenSCADFeatures.py got contaminated with some code from it, sorry about that.
keithsloan52
raymw
Postby raymw » Fri Oct 16, 2020 7:14 pm
Hi, Importing the hull.scad file, I get this
19:52:00 Traceback (most recent call last):
File "C:\Users\Ray\freecad19\FreeCAD_0.19.22284-Win-Conda_vc14.x-x86_64\Mod\OpenSCAD\OpenSCADFeatures.py", line 502, in execute
import Part, freecad.OpenSCAD.OpenSCADUtils
<class 'ModuleNotFoundError'>: No module named 'freecad.OpenSCAD'
I get the same for importing a minkowski
$fn =50;
minkowski() {
    cube([10, 10, 1]);
	cylinder(1);
All the main components cube/sphere/cylinder are imported OK, but the fiddly bits seem to fail. (I find it quicker to rough out the shape in openscad, import to freecad for filleting and otherwise finish, and export as stl. Exporting back to openscad for further editing is very iffy.
Best Wishes, Ray
sgrogan
Postby sgrogan » Fri Oct 16, 2020 7:19 pm
Are you going to make a pull request. I can if you don't have time.
keithsloan52
Postby keithsloan52 » Fri Oct 16, 2020 8:26 pm
Have a lot on my plate at the moment, eldest daughter passed her due date etc etc, so if you could do it that would be great.
sgrogan
Postby sgrogan » Sat Oct 17, 2020 9:44 am
Good luck and best wishes!
pull/3971
