[Bug 4480] Cross-document linking does not update on Recompute
mapeze
Post by mapeze »
In the past I successfully used the Cross-document linking feature as described here: https://wiki.freecadweb.org/Expressions
But now, after I edit the master cell value I can only update the slave cell value if I enter the cell to edit + press Enter or closing and opening the slave document.
Am I missing something?
Regards and lot of congratulations for this incredible work.
I attach the master and slave files I use for testing.
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.19.22846 (Git) AppImage
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Master.FCStd
(1.74 KiB) Downloaded 15 times
Slave.FCStd
(1.82 KiB) Downloaded 17 times
mapeze
Re: Cross-document linking does not update on refresh
Post by mapeze »
I tested with another two systems:
1) The update works as expected:
Version: 0.18.
Python version: 2.7.16rc1
Qt version: 5.11.3
2) The update does not work until I enter the slave cell and press Enter or I reopen the slave document
OS: Debian GNU/Linux 10 (buster) (XFCE/xfce)
Version: 0.19.21280 (Git) AppImage
Hash: 6f3160db3e88733536c7eaf97ad7d6ebd21baccd
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Basque/Spain (eu_ES)
Anyone willing to test in another system?
mapeze
Post by mapeze »
Another test with no slave update on refresh:
Qt version: 5.12.5
OCC version: 7.4.0
mapeze
Re: [Bug 4480] Cross-document linking does not update on Recompute
Post by mapeze »
The next versions works as expected:
Version: 0.19.16822 (Git) AppImage
Hash: 243aebf2dfbfe192b5bbd067020a5318a0fa8d0d
Python version: 3.7.1
Qt version: 5.6.2
rhprice2
Post by rhprice2 »
I am experiencing the same problem. Do you think there is a macro workaround? Would a forced recalculate solve the problem?
mapeze
Post by mapeze »
No idea about the macro workaround, but I found an ugly one:
- In the slave document, mark "skip recomputes" (not necessary, just safer if your slave is driving constraints of a model).
- Copy/cut/paste all cells of the slave's spreadsheet. All cells at once works well.
- Unmark "skip recomputes" if desired.
Once done, the update seems to work again until you reopen the slave. So the hack needs to be done once every time you work with the slave.
