[09/04/22][LinkStage3][UI] VertUI / Midnight UI
Report observations made with the new Toponaming branch.
br4n_d0n
Re: [19/07/21][LinkStage3][UI] Vertical UI
Post by br4n_d0n »
Wow, I just saw https://youtu.be/hl1kbGw_H1g for the first time and it mostly covers the issues I had when I first started using FreeCAD a little while ago. I even hopped on here to try and explain my thoughts of the issues I was having and in an effort to try and get a more "new user" friendly UI in another thread. I'm glad to see I'm not the only one who had these thoughts as well.
120ace
Post by 120ace »
Hello, I have been trying to get Vertical UI up and running. So far I have only been partially successful.
I am on Windows10 with FreeCADLink installed (FreeCAD-asm3-Stable-Win64-Py3-Qt5-20210717.7)
The default FreeCAD is a fresh install of the official 0.19.2 download (FreeCAD-0.19.2.7b5e18a-win-x64)
When I proceed to the registry FreeCAD is not listed under Computer\HKEY_CURRENT_USER\Software\FreeCAD, but rather Computer\HKEY_LOCAL_MACHINE\SOFTWARE\FreeCAD0192. It does not have a subfolder QT15, nor any subfolder at all. I still proceeded to make the necessary backups needed. I replaced the linstage3 Stylesheets folder with VertUI Stylesheets. Restarted FreeCAD, installed PersistentToolbars and TabBar, and switched the customize menu to the workbench tab. Rebooted and added the macro for InitGui.Py.
This is as far as I proceeded. At this point the colors of FreeCAD have changed to VertUI dark theme and TabBar is working. However, in the output console there is this: " 20:45:37 Cannot find icon: qss:overlay/transparent.svg
20:45:37 Cannot find icon: qss:overlay/autohide.svg
20:45:37 Cannot find icon: qss:overlay/edithide.svg
20:45:37 Cannot find icon: qss:overlay/editshow.svg
20:45:37 Cannot find icon: qss:overlay/taskshow.svg
20:45:37 Cannot find icon: qss:overlay/mode.svg
20:45:37 Cannot find icon: qss:overlay/overlay.svg
20:45:37 Cannot find icon: qss:overlay/float.svg
20:45:37 Cannot find icon: qss:overlay/close.svg
20:45:39 Cannot find icon: qss:overlay/float.svg
Also, when I try to change what workbenches are in TabBar all of the checkboxes are the same color as the UI box whether they are selected or not. One click in a checkbox does not change the box, however, it does remove the workbench from TabBar. One more click proceeds to change the checkbox to a white color.
Any help in fixing this would be very much appreciated.
Petrikas
Post by Petrikas »
120ace wrote: Wed Jul 28, 2021 1:54 am Hello, I have been trying to get Vertical UI up and running. So far I have only been partially successful.
Okay, no panic. I suppose I should've been more clear with my instructions.
Stylesheets folder was supposed to be dropped "on top" of the existing one, instead of replacing it.
Just in case if your old one - I've attached a complete Stylesheets folder that will fix your problem.
Sorry about that!
Stylesheets.zip
(257.61 KiB) Downloaded 80 times
I sometimes make FreeCAD Tutorials | VertUI | MidnightUI
120ace
Post by 120ace »
Hey, thank you! That fixed it. Everything works just fine now. BTW this is awesome.
Post by Kunda1 »
Just an aside, hopefully this whole process will get easier once chennes' PR gets merged
Cekuhnen
Re: [25/03/21][LinkStage3][UI] Vertical UI for large screens (4K)
Post by Cekuhnen »
Petrikas wrote: Mon Mar 29, 2021 10:15 pm While this was fun to make, it's a bit pointless, as it pushes everything to the left in a rather jarring fashion. Might be useful to uber-pros that work mainly by using shortcuts.
Oh man this instantly reminded about the old Amapi pro interface for some reason.
Very nice modern direction for the GUI
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Petrikas
Re: [17/10/21][LinkStage3][UI] Vertical UI
Post by Petrikas »
[17/10/2021] Update: Realthunder has made loading/merging/exporting configurations really easy, which simplified the installation process. New youtube video with instructions is also up.
https://forum.freecadweb.org/viewtopic. ... 18#p479818
carlopav
Post by carlopav »
Noce, also configurations pack PR by chennes was merged in FC master.
Would you consider making a similar tutorial for the master branch?
Petrikas
Post by Petrikas »
carlopav wrote: Sun Oct 17, 2021 6:23 pm Noce, also configurations pack PR by chennes was merged in FC master.
Absolutely, I've been wanting to make a video highlighting the UI/Themes related work that you both done lately on the original FreeCAD.
Not sure how possible VertUI is on the vanilla branch.
Arvoon_Mah
Post by Arvoon_Mah »
Hello, I'm currently using the Vertical UI with LinkBranch 17/10/21, it looks really good.
However, I have some icons that don't fit in the Vertical list (on the right) in many WorkBenches. How can I fix this please?
(Like in the v1 YouTube video on VertUI and Arch WB fix)
