I can reproduce. This seems like it might be related to that Workbench and the way Linkstage3 keeps toolbar info.bambuko wrote: ↑Tue Jan 11, 2022 5:06 pmHi, looks like I have found something dodgy when testing in the last few days.Petrikas wrote: ...
Dynamic Data workbench for some reason, populates it's toolbar across all others
Only dis-activating it solves the problem.
Hopefully someone can recreate and confirm, please?
I would recommend dropping it in the status bar (next to the 'measure tools' I've put there already), if you're having issues and you really need to use it.
Actually there's some info in DynamicData's InitGui:
#freecad hides wb toolbars on leaving wb, we unhide ours here to keep it around
#if the user has it set in parameters to do so
pg = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/DynamicData")
keep = pg.GetBool('KeepToolbar',True)
if not keep:
return
tb = window.findChildren(QtGui.QToolBar)
for bar in tb:
if "DynamicData Commands" in bar.objectName():
bar.setVisible(True)
