[09/04/22][LinkStage3][UI] VertUI / Midnight UI
Re: [LinkStage3][UI] Vertical UI for large screens (4K)
The ModernUI has only been a bad thing from my perspective. Dual monitors works perfectly using 0.19 but when I go to LinkStage I get crashes and the only way I can use it is to drag all my panels back to the main screen. There's no way I'm going to go back and forth doing this. I wish realthunder would just make his own config files.
When was the last time you checked? As mentioned before, he did make his own config files and they should be right there in you default FreeCAD config directory:freedman wrote: ↑Fri Feb 19, 2021 7:08 pm The ModernUI has only been a bad thing from my perspective. Dual monitors works perfectly using 0.19 but when I go to LinkStage I get crashes and the only way I can use it is to drag all my panels back to the main screen. There's no way I'm going to go back and forth doing this. I wish realthunder would just make his own config files.
link.user.cfg
link.system.cfg
OK, that's confusing. I thought the panel placement was stored in the config files but I get interaction in screen setups between 0.19 and Link. I'll have to go and check that again.
Running Link 11.130t
Okay, so even though Persistent Toolbars writes config to link.user.cfg, FreeCADLink does not load it.
Tried with a fresh install and cleared the registry keys, that information in the cfg is just not loaded. Only after re-applying the registry keys the toolbars appear in their intended spots.
See here also: https://forum.freecadweb.org/viewtopic. ... 54#p480443
The toolbars and Main Window are handled differently.
"fight the good fight"
I looked and your correct, the Link config files are there. I guess all this makes since if the data is stored in the Reg.Kunda1 wrote
link.user.cfg
link.system.cfg
- HakanSeven12
How can I do this?
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
[20/03/2021]
I have taken this over-complicated post down, as I'm working on a simplified versions that is easy to install for all.
- HakanSeven12
Nice Thanks
Updated to the latest version of turn211's ProDark stylesheet. [04-03-2021]
Fixed a dropdown margin bug.
At some point need to fork turn211's github, but as far as there's not much interest in this sidebar stylesheet, I'll attach to my replies.
