[09/04/22][LinkStage3][UI] VertUI / Midnight UI
Re: [25/03/21][LinkStage3][UI] Vertical UI for large screens (4K)
You might want to update to the my latest build of ProDark.qss Fixes abunch of bugs in later releases. Post if you find bugs. Keep up the good work!
Absolutely! Just waiting for the dust to settle down on your forum thread. Thanks for your work!
On an unrelated note, I need help figuring something out regarding QT:
I would like to make the text near the icons auto-hide, when the mouse isn't over the toolbars.
I first thought this could be done via :hover in qss, but QT won't allow changing widths dynamically through stylesheets.
Another way is to .setToolButtonStyle(QtCore.Qt.ToolButtonTextBesideIcon) and .setToolButtonStyle(QtCore.Qt.ToolButtonIconOnly), which seems to work dynamically, but I was unable to understand how to extract the mouse hover event from QT.
Please help?
Petrikas wrote: On an unrelated note, I need help figuring something out regarding QT:
@HakanSeven12 do you mind weighing in?HakanSeven12 wrote: pinged by pinger macro
- HakanSeven12
Firstly you need to install an event filter for your toolbars than create an event filter function to listen to event. You can chek if event type is enter or leave and do something when state is true. Here is my event filter for qdockwidgets in ModernUI.
https://github.com/HakanSeven12/Modern- ... ck.py#L134
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
You, Sir, are a genius. That totally works! Thanks!HakanSeven12 wrote: ↑Sun Mar 28, 2021 3:09 pm Firstly you need to install an event filter for your toolbars than create an event filter function to listen to event. You can chek if event type is enter or leave and do something when state is true. Here is my event filter for qdockwidgets in ModernUI.
- HakanSeven12
You are welcome
Much thanks for your input
- HakanSeven12
While this was fun to make, it's a bit pointless, as it pushes everything to the left in a rather jarring fashion. Might be useful to uber-pros that work mainly by using shortcuts.
Re: [19/07/21][LinkStage3][UI] Vertical UI
[19/07/21] Revived and updated this, but dropped support for Vanilla FreeCAD.
https://forum.freecadweb.org/viewtopic.php?f=8&t=55779
