Postby dg1727 » Sun Feb 21, 2021 1:09 pm
In the Part Design workbench, attempting a Boolean Cut with the Placement > Position > x of the first body at a nonzero value can cause the result of the boolean operation to be rotated 90 degrees even though nothing that the user did specified a rotation.
The issue doesn't happen with Boolean Fuse, for example. Also, in my testing, the first body needs to be a solid of revolution in order for the issue to appear.
- dg1727
