Jee-Bee wrote: ↑Fri Feb 26, 2021 11:22 am
First i think we have to split this off from the original topic!
Hello JB, may you take care of the splitting off ?. I do not know how do do it.
that a part is or an assembly is is very dependend on perspective.
I agree in priciple that the CAD document associated with a product may be organized in different ways depending on the perspective.
I do undersatnd very well what you are saying about the board and its components (your perspective is different than the perspective
of the component manufactuer). I am working on the same technical area.
But I never intended to tell if something should be defined as Part or as an Assembly in a given project.
I was just saying that, in the frame of mechanical CADs, there are many technical terms which are universally accepted.
the naming is not that importand to me
You may decide to call things differently but, if you want to comminucate with other experts in the fields, it is much better if you use the standard terminology. Previously you have mentioned a Board, a Resistor and a Sensor. I inderstood what you mean because these techical terms have a precise meaning.
Why do you think that using proper names is not important also when speaking about CAD concepts?
