I did some searching and eventually found this setting:
https://wiki.luxcorerender.org/LuxCore_ ... estimation
But I couldn't figure out what setting it should be and how I pass this parameter to luxcure, simply pasting it into the parameter box didn't work.
Maybe it is really easy but I couldn't find an answer.
[SDL][0.203] Camera type: perspective
[SDL][0.203] Camera position: Point[18.5759, -12.5029, 20.36]
[SDL][0.203] Camera target: Point[18.1664, -11.7935, 19.7864]
[SDL][0.203] Camera clipping plane disabled
Film size adjusted: 800x600 (Frame buffer size: 800x600)
RenderConfig has cached kernels: True
[LuxCore][0.203] Film resolution: 800x600
[SDL][0.203] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][0.203] Image pipeline: film.imagepipelines.0
[SDL][0.203] Image pipeline step 0: TONEMAP_AUTOLINEAR
[SDL][0.203] Image pipeline: film.imagepipelines.1
[SDL][0.203] Image pipeline step 0: TONEMAP_REINHARD02
[SDL][0.203] Image pipeline: film.imagepipelines.2
[SDL][0.203] Image pipeline step 0: NOP
[LuxRays][0.203] OpenCL support: enabled
[LuxRays][0.234] OpenCL Platform 0: NVIDIA CUDA
[LuxRays][0.234] CUDA support: enabled
[LuxRays][0.234] CUDA support: available
[LuxRays][0.234] CUDA driver version: 11.10
[LuxRays][0.234] CUDA device count: 1
[LuxRays][0.234] Optix support: available
[LuxRays][0.234] Device 0 name: Native
[LuxRays][0.234] Device 0 type: NATIVE_THREAD
[LuxRays][0.234] Device 0 compute units: 1
[LuxRays][0.234] Device 0 preferred float vector width: 4
[LuxRays][0.234] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][0.234] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][0.234] Device 0 has out of core memory support: 0
[LuxRays][0.234] Device 1 name: GeForce GTX 1060 6GB
[LuxRays][0.234] Device 1 type: OPENCL_GPU
[LuxRays][0.234] Device 1 compute units: 10
[LuxRays][0.234] Device 1 preferred float vector width: 1
[LuxRays][0.234] Device 1 max allocable memory: 6144MBytes
[LuxRays][0.234] Device 1 max allocable memory block size: 1536MBytes
[LuxRays][0.234] Device 1 has out of core memory support: 0
[LuxRays][0.234] Device 2 name: GeForce GTX 1060 6GB
[LuxRays][0.234] Device 2 type: CUDA_GPU
[LuxRays][0.234] Device 2 compute units: 128
[LuxRays][0.234] Device 2 preferred float vector width: 1
[LuxRays][0.234] Device 2 max allocable memory: 6144MBytes
[LuxRays][0.234] Device 2 max allocable memory block size: 17592186044415MBytes
[LuxRays][0.250] Device 2 has out of core memory support: 1
[LuxRays][0.250] Device 2 CUDA compute capability: 6.1
[LuxRays][0.250] Creating 16 intersection device(s)
[LuxRays][0.250] Allocating intersection device 0: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 1: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 8: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 9: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 10: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 11: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 12: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 13: Native (Type = NATIVE_THREAD)
[LuxRays][0.250] Allocating intersection device 14: Native (Type = NATIVE_THREAD)
[LuxRays][0.265] Allocating intersection device 15: Native (Type = NATIVE_THREAD)
[LuxCore][0.265] Configuring 16 CPU render threads
[LuxRays][0.265] Preprocessing DataSet
[LuxRays][0.265] Total vertex count: 0
[LuxRays][0.265] Total triangle count: 0
[LuxRays][0.265] Preprocessing DataSet done
[LuxRays][0.265] Adding DataSet accelerator: EMBREE
[LuxRays][0.265] EmbreeAccel build time: 0ms
[LuxCore][0.422] Film hardware image pipeline
[LuxCore][0.625] Film hardware device used: GeForce GTX 1060 6GB CUDAIntersect (Type: CUDA_GPU)
[LuxRays][0.640] [Device GeForce GTX 1060 6GB CUDAIntersect] IMAGEPIPELINE buffer size: 5625Kbytes
[LuxRays][0.640] [Device GeForce GTX 1060 6GB CUDAIntersect] Merge buffer size: 7500Kbytes
[LuxRays][0.640] [MergeSampleBuffersOCL] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D LUXRAYS_CUDA_DEVICE -D LUXRAYS_OS_WINDOWS --use_fast_math
[LuxRays][0.640] [MergeSampleBuffersOCL] Compiling kernels
[LuxRays][0.640] [MergeSampleBuffersOCL] Program cached
[LuxCore][0.640] [MergeSampleBuffersOCL] Compiling Film_MergeBufferInitialize Kernel
[LuxCore][0.640] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_PIXEL_NORMALIZED Kernel
[LuxCore][0.640] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_SCREEN_NORMALIZED Kernel
[LuxCore][0.640] [MergeSampleBuffersOCL] Compiling Film_MergeBufferFinalize Kernel
[LuxCore][0.640] [MergeSampleBuffersOCL] Kernels compilation time: 0ms
[LuxRays][0.656] [Device GeForce GTX 1060 6GB CUDAIntersect] Accumulation buffer size: 43Kbytes
[LuxRays][0.656] [AutoLinearToneMap] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D LUXRAYS_CUDA_DEVICE -D LUXRAYS_OS_WINDOWS --use_fast_math
[LuxRays][0.656] [AutoLinearToneMap] Compiling kernels
[LuxRays][0.656] [AutoLinearToneMap] Program cached
[LuxCore][0.656] [AutoLinearToneMap] Compiling OpRGBValuesReduce Kernel
[LuxCore][0.656] [AutoLinearToneMap] Compiling OpRGBValueAccumulate Kernel
[LuxCore][0.656] [AutoLinearToneMap] Compiling AutoLinearToneMap_Apply Kernel
[LuxCore][0.656] [AutoLinearToneMap] Kernels compilation time: 0ms
[LuxCore][3.172] Noise estimation: first pass
[LuxCore][5.890] Noise estimation: Error mean = 0
[LuxCore][11.328] Noise estimation: Error mean = 0
[LuxCore][16.797] Noise estimation: Error mean = 0
[LuxCore][22.562] Noise estimation: Error mean = 0
