[Render workbench} Getting it to work on Windows!
MisterMaker
Re: [Render workbench} Getting it to work on Windows!
Post by MisterMaker »
But what is the point of a ground plane if it is not covering the ground, then it is just a plane in the air!
The simplicity is perfect as it is, but the margin just needs to be 100 times bigger!
Edit:
Hacked the python files from the git page :)
2021-03-25 22_02_49-I’m something of a programmer myself _ r_ProgrammerHumor _ I'm Something of a Sc.png
2021-03-25 22_02_49-I’m something of a programmer myself _ r_ProgrammerHumor _ I'm Something of a Sc.png (314.45 KiB) Viewed 1458 times
This is perfect (the ground is the render looks bad :lol: ):
2021-03-25 22_06_49-Cycles_ CyclesProjectcn5xq1ll.xml.png (821.83 KiB) Viewed 1458 times
howetuft
Post by howetuft »
I was just doing the same, but adding it as a parameter in the project...
So, from now, there is a 'Ground Plane Size Factor' parameter in the project, you can set the value you want (default is 1, but any float value is allowed).
MisterMaker
howetuft wrote: Thu Mar 25, 2021 9:23 pm I was just doing the same, but adding it as a parameter in the project...
Yeah I saw you setting it up for me even before I knew I needed it! Awesome!
howetuft
Post by howetuft »
You're welcome, you're one of my best customers at this time :mrgreen:
MisterMaker
At this moment, but when we get nice renders with ease it will be awesome!
I am trying to start working in linux. It's not really easy so it's gonna take me some time!
DreiD21
Post by DreiD21 »
Help, I can't seem to get the Render Workbench to work on my Windows installation. I keep getting the following error messages, such as the following:
18:36:45 Running the Python command 'Render_Render' failed:
File "C:\Users\Andrei\AppData\Roaming\FreeCAD\Mod\Render\Render.py", line 1056, in Activated
project.Proxy.render()
File "C:\Users\Andrei\AppData\Roaming\FreeCAD\Mod\Render\Render.py", line 586, in render
ImageGui.open(img)
Could not load image file
I've attached a file that I'm working on. The individual objects are brought together using Assembly 4, and this is supposed to be used as a guide for assembling a larger machine. I need renders for the guide, and the Raytracing WB and POV-Ray Rendering WB can't add the objects into view for some reason (I think because Assembly 4 only links to the documents containing the original Body).
I'd rather work on this using assemblies because there are over 100 parts in the machine I'm modeling, and one sub-assembly will repeat 108 times!
Please help me!
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/Philippines (en_PH)
V-1906 Tangential Creel_individual feed rail-assm.FCStd
(8.21 KiB) Downloaded 36 times
V-1906 Tangential Creel_individual feed rail_bracket.FCStd
(32.71 KiB) Downloaded 39 times
V-1906 Tangential Creel_group guide rail_bracket_grommet.FCStd
(13.35 KiB) Downloaded 38 times
howetuft
Post by howetuft »
It appears that your files do not contain any rendering project, is that normal?
If I add a rendering project in 'V-1906 Tangential Creel_individual feed rail-assm', I can get the following rendering:
I attach the modified FCStd, for illustration.
Is that OK for you?
(19.28 KiB) Downloaded 35 times
