[Render workbench} Getting it to work on Windows!
Re: [Render workbench} Getting it to work on Windows!
Thank you for your feedback, I understand there may be some documentation effort to do.
- MisterMaker
Sure where should I make a wiki page in the freecad wiki that you can review when done?
Just as a hint: The wiki is already pretty clear about that as long as we talk about the wiki of the workbench on github.
https://github.com/FreeCAD/FreeCAD-rend ... Cameras.md
Rgrds, m.
Rgrds, m.
I am struggling with POV-Ray rendering a simple cube at the moment:
Luxcore project runs like a charm. POV-Ray throws an error. Did not invest much time in that so far. Any ideas? File enclosed.
Thanks in advance. m.
Renderer command: C:/Program Files/POV-Ray/v3.7/bin/pvengine64.exe +P +A +W800 +H600 +OC:/Portable Apps/FreeCAD/FreeCAD_latest/temp/FreeCAD_Doc_8e6646b9-00ea-40a2-b77d-3433433d4358_fe5d78_3428/PovrayProject1q8sux5j.png C:/Portable Apps/FreeCAD/FreeCAD_latest/temp/FreeCAD_Doc_8e6646b9-00ea-40a2-b77d-3433433d4358_fe5d78_3428/PovrayProject1q8sux5j.pov
08:51:38 Running the Python command 'Render_Render' failed:
File "C:\Portable Apps\FreeCAD\FreeCAD_latest\FreeCAD\Mod\Render\Render.py", line 1012, in Activated
project.Proxy.render()
File "C:\Portable Apps\FreeCAD\FreeCAD_latest\FreeCAD\Mod\Render\Render.py", line 560, in render
ImageGui.open(img)
Could not load image file
- test.FCStd
- (12.62 KiB) Downloaded 80 times
- MisterMaker
I checked your file and I had an issue with the correct location of the Povray template.
After I fixed that it worked for me, i got a blue cube.
I guess you use portable version, but I got the same error when this was broken.
I also had run the Povray installer but I forgot that I already had setup the portable povray version, soooo I am using that one. But maybe you can try to run the povray installer.
- 2021-03-24 11_56_08-.png (39.56 KiB) Viewed 2405 times
Yes, you have to update the path. Would be better to have a relative path here.MisterMaker wrote: ↑Wed Mar 24, 2021 10:59 am I had an issue with the correct location of the Povray template.
Are you talking about the portable version of PR or FC? I installed PR and it runs without problems with the "POV-Ray-Rendering" workbench. I run FC portable. The .pov file in generated in the /temp directory of FC with no problems. It is just that no image file was generated. I already checked that there are no blancs in any paths (this is a problem with the Appleseed integration). Still get the same error.MisterMaker wrote: ↑Wed Mar 24, 2021 10:59 am After I fixed that it worked for me, i got a blue cube.
m.
OK, just found the issue. This workbench has major problems as soon as you have blanks in paths! PR installs to "C:\Program Files" ... thats enough to run into the problem. Appleseed has the same issue. I will try to warp my head around this.
@MisterMaker
@Markymark
Just create a markdown file in 'docs' folder in github repo (send me a PR), I'll add a link to it in the main page. Thanks!Sure where should I make a wiki page in the freecad wiki that you can review when done?
@Markymark
I agree with you (relative path), the absolute path prevents portability, I'll try to think of a solution to this problem.Yes, you have to update the path. Would be better to have a relative path here.
- MisterMaker
I have cycles working on windows!
But it needs a lot of tweaking. But the basis is there.
First thing I really would like to change is the ground plane, it should be infinite or it should look like it is infinite!
I have uploaded the cycles stand alone build for windows here:
https://github.com/HaasNL2/Cycles-stand ... dows-build
After you download it you just have to edit the render workbench settings and point it there.
The resolution it renders is the resolution your window has.
It looks good, at least it looks the best of all the renders!
Great job! You can rest on the chair, now !!!
Then, if you want a more elaborate plane - other size, orientation, material etc. -, just create a plane in FreeCAD: https://wiki.freecadweb.org/Part_Primitives
Ground plane feature is aimed at being super-simple: one-click, no tweak - it is automatically sized on the scene bounding box.First thing I really would like to change is the ground plane, it should be infinite or it should look like it is infinite!
