Some way to isolate/separate body being edited
HoWil
Re: Some way to isolate/separate body being edited
Post by HoWil »
DeepSOIC wrote: Mon Mar 29, 2021 4:57 pm My Part-o-magic addon is all about that! Though it's not a separate view.
I used it years ago and can barely remember how it works.... Doesn't it need additional/non-standard FC containers? Does it modify the model so it is no more compatible to standard 0.19 FC?
Is it compatible with current fc versions and is it still developed?
BR
DeepSOIC
Post by DeepSOIC »
HoWil wrote: Wed Mar 31, 2021 5:59 am Doesn't it need additional/non-standard FC containers?
It does provide ones, but it doesn't "need" them, it will affect how Parts and Bodies behave and does not cause any incompatibility, except for actively changing display modes of bodies which may make some people think it makes models incompatible with vanilla freecad. But it doesn't really.
HoWil wrote: Wed Mar 31, 2021 5:59 am Is it compatible with current fc versions and is it still developed?
Mostly compatible, with the exception it may misbehave with Link-related stuff. It is not actively developed, but i'm trying to at least fix big bugs from time to time, because i use it myself.
paulo_cmv
Post by paulo_cmv »
- Correct some bugs
- Added use info
- Alternatively, bind it to some keyboard shortcut (im using Ctrl+spacebar)
# Togglevis is a macro created for FreeCAD .19 and is intended to toggle the visibility of selected/non selected objects to make it easer to edit when you have many objects in scene
# HOW TO USE: select the objects you want to keep visible (any vertex, edge, face will work) then run the macro.
# All non selected objects will be hidden.
# Run the macro again to restore previsous visibility state.
# - Alternatively, bind it to some keyboard shortcut (im using Ctrl+spacebar)
__title__    = "ToggleVis.py"
__author__   = "Paulo Rogerio de Oliveira"
__version__  = "1.0"
__date__     = "2021/03/31"    #YYY/MM/DD
__Comment__  = "Hide unselected objects so you can edit then easily. restore prior visibility state running the macro again"
__Help__     = "Select objects you must keep visible and run the macro. Run it again to restore previsous visibility."
__Status__   = "stable"
__Requires__ = "freecad 0.19 (not tested in previous versions)"
import FreeCAD
import PySide
from PySide import QtGui ,QtCore
from PySide.QtGui import *
from PySide.QtCore import *
# clear output window
mw=Gui.getMainWindow()
#	c=mw.findChild(QtGui.QPlainTextEdit, "Python console")
#	c.clear()
#	r=mw.findChild(QtGui.QTextEdit, "Report view")
#	r.clear()
#initialize cache
if not hasattr(FreeCAD, "previouslyVisibleObjects"):
	FreeCAD.previouslyVisibleObjects=[]
if not hasattr(FreeCAD, "previouslyHiddenObjects"):
	FreeCAD.previouslyHiddenObjects=[]
# store all parents of all selected objects to ensure its keep visible (store the Label)
# for parentList and selectedList, store the QTreeWidgetItem reference. Try to avoid error if change label while in edit mode
parentList = []
selectedList = []
# try to get internal object associated with QTreeWidgetItem
def getInternalObject(treeItem):
	# first looks by Label
	obj = App.ActiveDocument.getObjectsByLabel(treeItem.data(0,0))
	if len(obj) > 0:
		return obj[0]
	else:
		# if not found, looks by Name
		return App.ActiveDocument.getObject(treeItem.data(0,0))
	pass
# for each object in treeview
def traverse(list, pad):
	# for each child
	for idx in range(list.childCount()):
		item = list.child(idx)
		name = item.data(0, 0)
		obj = getInternalObject(item)
		isParent = name in parentList
		isSelected = name in selectedList
		# hide any object that is visible and not parent of selected or selected itself - store it on list to restore state later
		if obj.Visibility == True and not isParent and not isSelected:
			obj.Visibility = False
			FreeCAD.previouslyVisibleObjects.append(item)
		# if not selected, not a group or if its parent of selected, traverse childs
		if not isSelected:
			if not hasattr(obj, "Group") or isParent:
				traverse	(item, pad + "  ")
# if there are objects in visibility cache, you are in edit mode
inEdit = len(FreeCAD.previouslyVisibleObjects) > 0
if inEdit:
	FreeCAD.Console.PrintWarning("Leaving edig mode...")
	# show all objects that where visible when entered edit mode
	for object in FreeCAD.previouslyVisibleObjects:
		obj = getInternalObject(object)
		try:
			obj.Visibility = True
		except:
			pass
	# hide all objects that where hidden when entered edit mode
	for object in FreeCAD.previouslyHiddenObjects:
		try:
		except:
			pass
	# reset visibility cache
	FreeCAD.previouslyVisibleObjects = []
	FreeCAD.previouslyHiddenObjects = []
	#FreeCADGui.SendMsgToActiveView("ViewFit")
else:
	tab = mw.findChild(QtGui.QTabWidget, u'combiTab')
	tree = tab.widget(0).findChildren(QtGui.QTreeWidget)[0]
	top = tree.invisibleRootItem().child(0)
	# get selected objects
	sels = FreeCADGui.Selection.getSelection()
	if not sels:
		FreeCAD.Console.PrintWarning("Select something first!\n\n")
	else:
		FreeCAD.Console.PrintWarning("Entering edit mode!\n\n")
		# find the treeitem for ActiveDocument
		for idx in range(top.childCount()):
			doc 	= top.child(idx)
			if doc.data(0,0) == App.ActiveDocument.Label:
				top = doc
		# store a list of selected items and its parents to keep it visible
		for sel in tree.selectedItems():
			current = sel
			selectedList.append(current.data(0,0))
			while current != None:
				obj = getInternalObject(current)
				if hasattr(obj, "Visibility") and obj.Visibility == False:
					FreeCAD.previouslyHiddenObjects.append(current)
				current = current.parent()
				if current != None:
					parentList.append(current.data(0,0))
		traverse(top, "")
paulo_cmv
Post by paulo_cmv »
mario52 wrote: Mon Mar 29, 2021 4:24 pm good macro, when it is finished you must adding in Macro Recipes section 3D View operations with Macro Toggle Visibility (serial)
How can it be made?
How can i ask to add it to Addon Manager / Macros?
Syres
Post by Syres »
paulo_cmv wrote: Wed Mar 31, 2021 2:16 pm
Rogério de Oliveira"
You'll have a lot of grumpy English lang users, best to remove any accents at this stage!!
Give errors such as:
15:32:40  <class 'SyntaxError'>: ("(unicode error) 'utf-8' codec can't decode byte 0xe9 in position 9: invalid continuation byte", ('E:/Data/FreeCAD/Macro/EditMode.FCMacro', 9, 16, None))
paulo_cmv
Post by paulo_cmv »
Ok. Ill have to review this. I copied this section from another macro. Will keep only the how to use...
mario52
Post by mario52 »
Hi
see here How to get wiki editing permissions
see Macro_documentation
you create your page and not forgote create a link for your wiki page in this page Macros_recipes
thanks for your macro
mario
Brutha
Post by Brutha »
paulo_cmv wrote: Wed Mar 31, 2021 2:16 pm - Correct some bugs
- Added use info
Thanks for the macro! However, on my system I get the following error when I try and use it:
  File "/Users/XXXXXX/Library/Preferences/FreeCAD/Macro/ToggleVisibility.FCMacro", line 121, in <module>
<class 'NotImplementedError'>: operator not implemented.
Strange because I can do the following in the console:
>>> 1 != 2
True
>>> 1 != 1
False
Here's my system info:
OS: macOS 10.15
Version: 0.20.24612 (Git)
Hash: f525904c1be10a0f55aa3502151c2c55e5054259
Python version: 3.9.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Locale: C/Default (C)
Any ideas?
Cheers
Brutha
Syres
Post by Syres »
Brutha wrote: Sat Apr 10, 2021 2:15 pm
Any ideas?
Try replacing the section:
				if current != None:
with:
			while current:
				if current:
I don't have Python 3.9.x to test with at present but tweak this still works on 3.8.x and is a little more Pythonic IMHO so I'm hoping it gets you up and running.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.24673 (Git)
Hash: e66ed26769ce8affe0a4ed330ff0435f4802f05e
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
HoWil
Post by HoWil »
DeepSOIC wrote: Wed Mar 31, 2021 12:28 pm
Would be nice to see this functionality in main FC.
