[Solved] Ticket #4612 - No colors are visible when opening an existing STEP file
Postby Kunda1 » Thu Apr 01, 2021 5:06 pm
Discussion thread for issue #4612: No colors are visible when opening an existing STEP file
Re: Ticket #4612 - No colors are visible when opening an existing STEP file
Postby chrisb » Thu Apr 01, 2021 5:55 pm
I cannot confirm. The attached step was created in FreeCAD with two red sides and it import with the same colors.
OS: macOS 10.16
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
Cube.step
(16.23 KiB) Downloaded 1 time
Syres
Postby Syres » Thu Apr 01, 2021 6:19 pm
I'm with @chrisb on this, 0.19.1 exports and imports colours fine. I also brought a STEP file that I exported with colours on certain faces from 2017 and it worked as expected.
The thing that stood out to me looking at the bug report is the reporter had both 0.18.x and 0.19.1 open together and therefore highly likely to be using the same config files. This is a big no-no now that so much has changed between the versions, I've even started with a set of 0.20 config files so I know for certain there's no 'pollution' across when I'm opening old files in the version they were built with.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
alexpro
Postby alexpro » Thu Apr 01, 2021 8:14 pm
I installed V0.19 on another computer before I replaced my version. That computer never had FreeCad installed on it. I completely uninstalled my version 0.18, did a reboot and then installed V0.19 on it. I have the same problem with no colors showing.
I was able to see your cube with the 2 red sides without any problem.
I included the step file that I showed in my initial message.
OS: Windows 10 Version 2009
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
LED_591_Yellow.zip
Step file sample
(384.47 KiB) Downloaded 1 time
Postby chrisb » Thu Apr 01, 2021 9:06 pm
It's yellow here. It must be your import options.
Postby chrisb » Thu Apr 01, 2021 9:11 pm
Disable in the import options "Enable STEP compound merge".
alexpro
Postby alexpro » Thu Apr 01, 2021 9:49 pm
That took care of it!
Thanks! Working great now. Glad to see that custom colors are now saved in the palette once again.
Alex
